Official TVS Thread!!!
#4226
I would assume a gmr is slightly smaller, than this port. Remembering back to my flow bench numbers. Few years back, iirc it flowed roughly 10 Cfm less on a pretty small port.
This port generally drops 3-4 lbs of boost also
#4234
Will a larger port make more power? yes, in some cases. However not everyone can utilize a larger power. Without the proper setup a car can lose power, and down low performance, due to lack of velocity
#4239
I agree to a point. Velocity is still important, but not as mush as n/a. On na the scavenging is more important.
Now I am NOT saying to hell with velocity!
Just simply observing that we have boost shoving fresh air in, without the restrictin of a turbo
#4241
I disagree that you lose low end performance when opening up the port, That's like saying.....oh I put a ported head and header/3" exhaust now my car has no power down low.
Now, if you put a huge port, and 3" exhaust on a stock pulley car, it will suffer down low, that's why I said, it must be utilized.
Throttle response is also imporoved by very little port work
#4242
On my ex's redline, I had a head I did some experienting on and went a little overboard with, when her car busted pistons...tune related, we swapped a that head onto it, it ran as well as a gmstg2 car, but suffered some down low power. After we added a 2.9 to it, it woke it up pretty well, but still wasn't as snappy down low as it could have been from a smaller port, it really came aline around 4000 rpm though.
Also, mr. b had a HOGGED out head on his car and after swapping to a less aggressive port that I did for it, it gained 20 hp on the dyno.
It all depends on what your mods are and how well you can use it.
#4243
#4245
I really need one of those nifty sig's
Any takers?
#4247
Any lsj can benefit from porting, the amount of port work needed is dependant.
The most gains from a ported head will be seen from say a 2.9 tvs then switching to a ported head.
My 2.8 tvs and ported head setup was nasty
