Official TVS Thread!!!
Old 01-31-2013, 10:43 PM
  #4226
lsjion's Avatar
I would assume a gmr is slightly smaller, than this port. Remembering back to my flow bench numbers. Few years back, iirc it flowed roughly 10 Cfm less on a pretty small port.
This port generally drops 3-4 lbs of boost also
Old 01-31-2013, 11:15 PM
  #4227
South Central *********
JapEatr's Avatar
Josh is correct there is no need to hog the port out when in fact you will loose power
Old 02-01-2013, 12:02 AM
  #4228
zrated89's Avatar
when my head was ported by joe this is exactly what we did. To big youll disrupt velocity and lose power
Old 02-01-2013, 01:09 AM
  #4229
RooTBeeR's Avatar
i like that sound of that!
hmm, once i pull this engine...not sure if should fully build it, or just do head port...or just leave it alone
Old 02-01-2013, 09:36 AM
  #4230
mrbelvedere's Avatar
tell that to infra
Old 02-01-2013, 10:54 AM
  #4231
Rent me! per hour
Area47's Avatar
increasing cfm while maintaining and/or increasing port velocity.
hogging increases cfm, but tanks the velocity.
Old 02-01-2013, 11:24 AM
  #4232
when your forcing velocity dosent matter as much
Old 02-01-2013, 11:31 AM
  #4233
Rent me! per hour
Area47's Avatar
Old 02-01-2013, 11:46 AM
  #4234
lsjion's Avatar
Will a larger port make more power? yes, in some cases. However not everyone can utilize a larger power. Without the proper setup a car can lose power, and down low performance, due to lack of velocity
Old 02-01-2013, 11:48 AM
  #4235
lsjion's Avatar
larger port* not power.
for some reason I don't have the ability to edit my posts
Old 02-01-2013, 11:51 AM
  #4236
as soon as the ex port is opened up bottom end is lost and and power is shifted up velocity is more important on a n/a engine
Old 02-01-2013, 12:02 PM
  #4237
RooTBeeR's Avatar
All I want is down low performance. Need that off the line/idle grunt...so much that if I lose some top end power I don't mind
Old 02-01-2013, 12:13 PM
  #4238
then leave it alone
Old 02-01-2013, 12:14 PM
  #4239
armcclure's Avatar
I agree to a point. Velocity is still important, but not as mush as n/a. On na the scavenging is more important.
Now I am NOT saying to hell with velocity!
Just simply observing that we have boost shoving fresh air in, without the restrictin of a turbo
Old 02-01-2013, 12:17 PM
  #4240
RooTBeeR's Avatar
I need to advance the cam/s too, peak power by 6k with a stump pulling tq band
Old 02-01-2013, 01:00 PM
  #4241
lsjion's Avatar
I disagree that you lose low end performance when opening up the port, That's like saying.....oh I put a ported head and header/3" exhaust now my car has no power down low.
Now, if you put a huge port, and 3" exhaust on a stock pulley car, it will suffer down low, that's why I said, it must be utilized.
Throttle response is also imporoved by very little port work
Old 02-01-2013, 01:05 PM
  #4242
lsjion's Avatar
On my ex's redline, I had a head I did some experienting on and went a little overboard with, when her car busted pistons...tune related, we swapped a that head onto it, it ran as well as a gmstg2 car, but suffered some down low power. After we added a 2.9 to it, it woke it up pretty well, but still wasn't as snappy down low as it could have been from a smaller port, it really came aline around 4000 rpm though.
Also, mr. b had a HOGGED out head on his car and after swapping to a less aggressive port that I did for it, it gained 20 hp on the dyno.
It all depends on what your mods are and how well you can use it.
Old 02-01-2013, 01:13 PM
  #4243
Vander Nars's Avatar
im have to get me a spare head as some point so I can get u to port it, u seem to really know what ur doing.
Old 02-01-2013, 01:19 PM
  #4244
RooTBeeR's Avatar
Hmmm, Zzp stg2 cams + GMT can gears + advanced cams = funky powers lol
Old 02-01-2013, 01:27 PM
  #4245
lsjion's Avatar
I've been doing it for a few years now, and all of my friends have ran one, or will in the very near future. I've seem to have lost count of how many are out there.
I really need one of those nifty sig's
Any takers?
Old 02-01-2013, 01:37 PM
  #4246
RooTBeeR's Avatar
So a tvs w/2.9" on 91 could surely take advantage of exhaust porting
Old 02-01-2013, 01:40 PM
  #4247
lsjion's Avatar
Any lsj can benefit from porting, the amount of port work needed is dependant.
The most gains from a ported head will be seen from say a 2.9 tvs then switching to a ported head.
My 2.8 tvs and ported head setup was nasty
Old 02-01-2013, 01:41 PM
  #4248
lsjion's Avatar
The more boost that is present,,,, like a 2.6 m62 could greatly benefit from a ported head, Especially with the drop in boost
Old 02-01-2013, 01:52 PM
  #4249
Got Bewst?
Bluelightning's Avatar
I'm definitely looking forward to the drop in boost
Old 02-01-2013, 01:57 PM
  #4250
RooTBeeR's Avatar
"Lowered boost" yields a better efficiency range
Might just stick with the 3.15 and crank some timing into it...
2.9 though, all the extra boost coming on sooner should give me more of The tq im looking for...want/ need a custom long tube or maybe even tri-y.
Quick Reply: Official TVS Thread!!!
