Official TVS Thread!!!
Old 03-01-2013, 01:52 PM
  #4751
SSfamilywagon's Avatar
Thanks guys. A repolish is definitely in order. I got a couple more things to buy and will out this puppy on.
Ooooooo did someone say *****!!!
Old 03-01-2013, 02:47 PM
  #4752
advise's Avatar
Just got my used head looks like on the exhaust side the rockers made contact with the titanium retainers
Any reason this would happen?
Old 03-01-2013, 03:25 PM
  #4753
Rent me! per hour
Area47's Avatar
last i knew of there was only one polished tvs floating around
Old 03-01-2013, 03:40 PM
  #4754
lsjion's Avatar
post a picture advise
Old 03-01-2013, 04:20 PM
  #4755
I believe you are correct. I've only seen one myself too.
Old 03-01-2013, 06:46 PM
  #4756
InfraRedline's Avatar
So mathematically you'll be at 7,960 for the same mph...
Hmmmm.....Challenge accepted
Originally Posted by SSfamilywagon
I'll just leave this here! Very happy to join the club!!
Welcome to the club lol
Old 03-01-2013, 06:48 PM
  #4757
advise's Avatar
only one i have right now will get more in a little bit
the previous owner rotated the retainer twice thats what the 2 lines you can see are and theres a third under the rocker arm
any ideas, also where can i get 8 new ti retainers for my supertech springs
Old 03-01-2013, 07:47 PM
  #4758
Powell Race Parts's Avatar
the valves do rotate in the head btw. You can remove the rockers and surface grind them for clearance. Its a matter of thousandths of an inch. It only happens on the exhaust side.
I have found this happens if you put LNF new style rockers on an LSJ and why Supertech came out with a new spring package for LNFs. Based on what I have found and experienced, its not the end of the work; fix the clearance and you will be fine and the Ti retainers dont need to be replaced... at least on mine, the marks dont hurt. Yours look a little nastier than the ones I had but I dont know what else. Talk to Supertech if you wish they are really decent people to deal with and very knowledgeable.
Old 03-01-2013, 08:09 PM
  #4759
advise's Avatar
Thanks John I forgot these are the older springs
Do you know if the new ti retainers are the same size
Old 03-01-2013, 08:25 PM
  #4760
supertech changed the spring I doubt they changed the retainer. Ya never know I didnt ask at the time. The issue with the LNF was two fold: the contact with the rocker, and the compressed spring having a larger compressed circumference than the head pocket.
The LSJ head has different architecture to the LNF, not just the inlet port angle and the DI injectors, but the spark plug surround boss has tent style structure, and the LNF is just open in that area.
So I dont know for sure, but I am guessing that the old LSJ rockers which were cracked at the pivot even when they were manufactured, were upgraded for the LNF. That leads to a retainer clearance issue I am thinking. And the casting for the LNF head was changed, maybe simplified for production ( I like the "look" of the LSJ head better but wtf do I know about casting structure? Nothing.) and the spring pockets evidently slightly smaller than the LSJ
all I know.
Old 03-01-2013, 09:41 PM
  #4761
Thanks man!! Hoping to be nipping at your toes for times soon. Like to get mine up there.
Old 03-01-2013, 10:27 PM
  #4762
advise's Avatar
all I know.
Also looks as if the springs don't clear the head pocket?
Old 03-02-2013, 12:05 AM
  #4763
zrated89's Avatar
da phauq does gds mean?
Old 03-02-2013, 12:06 AM
  #4764
advise's Avatar
Anyone know if I could machine the retainers a few thousands
Old 03-02-2013, 12:09 AM
  #4765
zrated89's Avatar
yes u could take a whiz wheel to the top. its the bottom that matters as far as the support and retention goes
Old 03-02-2013, 12:11 AM
  #4766
zrated89's Avatar
i would do it just to clean them up though not for clearance. take some off the roller bottom like john said
Old 03-02-2013, 12:33 AM
  #4767
armcclure's Avatar
Do you happen to have any pics or examples of this in your vast database?
Old 03-02-2013, 12:37 AM
  #4768
advise's Avatar
The heads getting decked tomorrow figured I'd just have the machinest clean up the retainers and fix my pocket clearance issue
Where would I grind the rocker arm
Old 03-02-2013, 12:46 AM
  #4769
armcclure's Avatar
By what he was saying I'm assuming the flat bottom side, around the nub for the valve. Ill let him clarify though.
Old 03-02-2013, 09:31 AM
  #4770
yup. Advise sent me a PM I will send piks and specs Monday. Maybe if I can do it myself, earlier, but I have lots of stuff to assemble and ship out so gotta take care of that first. And I be feeling lazy. And Roger the engine man I think for him, its last weekend for ice fishing...what a curious sport. Sit in a tiny shack over a hole in the ice, drink beer in the freezing cold, catch fish which are generally so small,you throw them back?....now thats a good time!.......
Old 03-02-2013, 10:32 AM
  #4771
advise's Avatar
Anyone know what the clearance should be so I can check it when installed
Think I'm gonna have the machine shop cut the retainers
Old 03-02-2013, 10:40 AM
  #4772
Weakening the retainers is probably not the best thing to do...
Old 03-02-2013, 10:58 AM
  #4773
armcclure's Avatar
Agreed. Just looking at it from a structural standpoint, the rocket is a lot beefier than the retainer. It can lose a few thousandths without being affected like the retainer would be.
Old 03-02-2013, 01:44 PM
  #4774
advise's Avatar
I'm going to contact supertech and see if I could get the 75lb springs and avoid both these issues
It is a manufacturing defect that that there too large for the spring pocket
Old 03-02-2013, 03:26 PM
  #4775
if you run stock LSJ rockers it doesnt happen. NOT a defect and its not fair to say that. Your head does not have stock LSJ rockers and thats the root cause of the problem. My .02 c.
Quick Reply: Official TVS Thread!!!
