Official TVS Thread!!!
#5126
South Central *********
not sure how the GMRs compare to the Comps tho as far as torque goes.
here is a dyno graph from two setups not even close to each other.
but it does show a TVS only setup versus a cammed and built motor setup which i think most do when going for the cam package on the TVS.
not proof positive i realize, but the torque is available down low
#5134
Fair enough, but havi g the ***** to try it doesn't make up for not compensating for the smaller base circle with the right hardware. Don't get me wrong, not belittling your accomplishments by any means, just stating what I see.
#5140
Belvedere says: dyno is bragging rights. 1320 is the true story.
So, I say its all over at the 60ft.
so all you heros go to the 1320 and post up the results: tvs stock cam, compared to tvs s2 cams, two cars, two drivers same day ;switch drivers in the cars three runs each.
then you got something to talk about .
aintgonnahappen.com.
PS I have dyno sheets on all the cam combos I have mentioned we have built
#5146
#5147
