Official TVS Thread!!!
Old 04-05-2013, 09:44 AM
  #5426
robertmichaels's Avatar
The second pic is a bit confusing is this right?
Old 04-05-2013, 09:49 AM
  #5427
advise's Avatar
Originally Posted by mrbelvedere
you don't want to run a catch can a catch can is vented to atmosphere you want to run a good air/oil separator and make it a closed system I run a moroso setup with -10 lines
Exactly what i have, just need to get rid of my oil cap adapter and run a -10 on the back of my valve cover or remove my baffles
Old 04-05-2013, 10:00 AM
  #5428
mrbelvedere's Avatar
you put your can over the header
Old 04-05-2013, 10:22 AM
  #5429
advise's Avatar
It's too the left of the #4 primary
Old 04-05-2013, 10:51 AM
  #5430
nice setup only thing I would do is put a heat shield under it
Old 04-05-2013, 11:12 AM
  #5431
Got Bewst?
Bluelightning's Avatar
Reason?
Old 04-05-2013, 11:40 AM
  #5432
South Central *********
JapEatr's Avatar
belvedere, you got some photos of removing the baffles in the VC? any chance you got a spare VC laying around?
Old 04-05-2013, 11:41 AM
  #5433
574
574's Avatar
I can get you one if needed
Old 04-05-2013, 11:43 AM
  #5434
JapEatr's Avatar
the part i had to cut was on the bottom section of the housing, the chamber if you will
YMMV
Old 04-05-2013, 11:47 AM
  #5435
JapEatr's Avatar
are you RSFS 574?
Old 04-05-2013, 11:56 AM
  #5436
574
574's Avatar
are you RSFS 574?
No sir just id1000 and dw300
Old 04-05-2013, 12:08 PM
  #5437
JapEatr's Avatar
then you will need to keep the check valve
Old 04-05-2013, 12:19 PM
  #5438
Rent me! per hour
Area47's Avatar
Started with an m62, now im here
wtf is jb welded to the valve cover?
Old 04-05-2013, 12:32 PM
  #5439
Reason?
am open air system creates a air leak
you don't want to remove the baffles and sep plate leave them in place they work wonderfully gm never removed that stuff either on their race engines
Old 04-05-2013, 12:34 PM
  #5440
JapEatr's Avatar
so how do you enlarge the port on the VC and retain the plastic baffles?
Old 04-05-2013, 12:35 PM
  #5441
advise's Avatar
i have a spare cover if you need
Old 04-05-2013, 12:36 PM
  #5442
JapEatr's Avatar
weld me a -10 on it and ill take it?!
Old 04-05-2013, 01:21 PM
  #5443
advise's Avatar
Pm me a price and you got a deal
Old 04-05-2013, 01:29 PM
  #5444
nothing lol. i see whatever that is in the picture though appears that way. i assure you there is NO crap jobs like that in my car
Old 04-05-2013, 01:53 PM
  #5445
you weld a -10 bung over the crankcase vent on the back of the v cover
Old 04-05-2013, 01:59 PM
  #5446
Rent me! per hour
Area47's Avatar
it's somethin dammit!
brass fitting as well
:P
Old 04-05-2013, 02:30 PM
  #5447
Administrator
Administrator
Staged07SS's Avatar
:P
Ur loosing it. Buying that Toyota has messed up your mind
Old 04-05-2013, 02:47 PM
  #5448
Rent me! per hour
Area47's Avatar
perhaps.
Old 04-05-2013, 03:37 PM
  #5449
RooTBeeR's Avatar
perhaps.
You silly breeder.
Old 04-05-2013, 05:18 PM
  #5450
574- Where did you get the Id1000's And what did you do to get them to work ( pins and clips with what harness)
Quick Reply: Official TVS Thread!!!
