Official TVS Thread!!!
Old 04-10-2013, 02:11 AM
  #5526
RooTBeeR's Avatar
Old 04-10-2013, 08:50 AM
  #5527
100% METH's Avatar
You guys comparing a k20 to the lsj again?
Old 04-10-2013, 09:04 AM
  #5528
Administrator
Administrator
Staged07SS's Avatar
Old 04-10-2013, 09:20 AM
  #5529
dead horse - meet beating.
Old 04-10-2013, 09:34 AM
  #5530
jonathan923's Avatar
the 1900 fit with some hacking to the front by the pulley.
3.6 pulley, 25-26 psi... I'm all for big blowers... even with a hogged head and a 2.4... a 2300 may just be to much.
holy ****! thats like 3 m62s strapped together..
now, how do you even tightened the bolts on that thing? thats crazy
Old 04-10-2013, 12:37 PM
  #5531
armcclure's Avatar
Originally Posted by bratboy90
I'm betting $20 that he makes power.... dumbest statement ever. Now is it better than smaller blowers I don't know...
Holy **** über tooner take a dose of sarcasm and sit the **** down.
Old 04-10-2013, 12:42 PM
  #5532
RooTBeeR's Avatar
No, k24
you don't, the intake and a belt hold on
Old 04-11-2013, 12:09 AM
  #5533
100% METH's Avatar
Lol
It was a tight fit
Old 04-11-2013, 12:32 AM
  #5534
RooTBeeR's Avatar
It sure made a pretty nice loud whine on your car too
Old 04-11-2013, 08:29 PM
  #5535
wRcKLes's Avatar
Kinda a n00b question but will the 3.1 pully on a tvs fit with a pheolnic spacer and the stock belt?
Old 04-11-2013, 09:13 PM
  #5536
South Central *********
JapEatr's Avatar
Yes
Old 04-11-2013, 09:24 PM
  #5537
wRcKLes's Avatar
Thanks again
Old 04-11-2013, 09:47 PM
  #5538
Powell Race Parts's Avatar
baby dont do it. lol
Old 04-11-2013, 10:24 PM
  #5539
ThexGovenor's Avatar
Should be able to go below a 3.1 pulley though.
Old 04-12-2013, 08:48 AM
  #5540
100% METH's Avatar
Yeah it whined a lot for a 3.6 pulley
I hve video of it on my computer at home
Old 04-12-2013, 06:17 PM
  #5541
Tjolley's Avatar
Originally Posted by 574
TVS 1900 + 2.4 stroker... lawd why hasn't anyone done this?!
(I already know, lack of money. It was a rhetorical question)
But seriously someone needs to do this
I think the le5 crank is only good to 600-700 hp..Im afraid to break it but if that happens then ill have to buy a gen3 block and have crower custom make me a crank with 112mm stroke on it.. 2.7 stroker oh ya.
Another 8k into the car.
The only thing holding me back from the 1900 now is my trans. Im not sure if the issue is the trans or the cables. If it ends up being a trans issue im gona do a f40 swap.
Old 04-12-2013, 06:26 PM
  #5542
armcclure's Avatar
I think a lot if people should stop being so scared of properly set up nitrous...
Old 04-12-2013, 06:29 PM
  #5543
Rent me! per hour
Area47's Avatar
most people don't know how
Old 04-12-2013, 06:31 PM
  #5544
armcclure's Avatar
True. And the stereotype it received from all the f&f movies sure didn't help. I'm setting mine up with a lazy blower and a nitrous express kit ran off of a maximizer4 progressive controller. With a nano nitrous assist kit.
The things you can do with the NEW max4 controller (not FS to public yet, I'm special.) are crazy. Complete control of everything.
Old 04-12-2013, 06:41 PM
  #5545
Rent me! per hour
Area47's Avatar
probably similar to the old fjo controller
Old 04-12-2013, 06:45 PM
  #5546
Tjolley's Avatar
I just like it to hit at 3500 to 7250. 75shot seems to do the trick at keeping the iat2s in check.
Old 04-12-2013, 07:29 PM
  #5547
armcclure's Avatar
Similar. But better. The original had tons of options, this one you can use all of them together. For example, set a base %, say 25% at 50 mph to 100% at 80. Then you can still ramp in at a desired rate on top of that after shifting.
Then run your wideband 0-5 into it for compete safety. Tell it your target afr and if something changes in the system, either bottle pressure drop or a fuel pressure drop, even fuel failure, it will automatically vary the solenoid pw to maintain that afr, to the point of shutting the system off in case of a fuel failure.
I'm excited.
Old 04-14-2013, 06:13 PM
  #5548
Blairwolf's Avatar
I just sent a head to lsjion, should i have him port just the exhaust side or do intake and exhaust? I will be running stage 2 cams. Other mods are in my sig.
Old 04-14-2013, 06:19 PM
  #5549
armcclure's Avatar
I think you should untrust that to him. He usually does a very mild flashing cleanup on the intake iirc.
Old 04-14-2013, 06:22 PM
  #5550
I dont think it is possible to open up the exhaust enough to maintain the balance inlet/exhaust that is needed. If we assume that GM racing were correct, and just porting the exhaust gave the right performance balance for the supercharged engine, with the existing inlet port, it makes sense that if you open up the inlet any, you need to go even bigger on the exhaust port than the GMR CNC exhaust port config. That is possible based on my flow numbers from bench testing, but if it was my money I would only do the exhaust. Billabong has had some good results though.
I run GMR heads.
Quick Reply: Official TVS Thread!!!
