Official TVS Thread!!!
Old 04-22-2013, 11:44 PM
  #5701
mrbelvedere's Avatar
I ran the zzpstg2 cams over on the rl forums in the tuning section is a how to on camshaft tuning it helped me
Old 04-23-2013, 09:10 AM
  #5702
advise's Avatar
Should the lsa between the intake and exhaust be as different as it is
Old 04-23-2013, 10:01 AM
  #5703
yea
Old 04-25-2013, 11:34 AM
  #5704
advise's Avatar
What guys doing about id1000s going past the injector cups
Old 04-25-2013, 12:01 PM
  #5705
Rent me! per hour
Area47's Avatar
i put small o-rings on the stainless steel part of the body. search for pics of it.
Old 04-25-2013, 12:02 PM
  #5706
574
574's Avatar
Are you talking about because they get stuck in there?
Old 04-25-2013, 12:17 PM
  #5707
Rent me! per hour
Area47's Avatar
the small lime green o-ring.
Old 04-25-2013, 12:23 PM
  #5708
advise's Avatar
Thanks!
Old 04-25-2013, 12:37 PM
  #5709
574
574's Avatar
When I pulled mine out the cups came out of the head
Old 04-25-2013, 01:21 PM
  #5710
zrated89's Avatar
yea orings on the body for sure
Old 04-25-2013, 01:26 PM
  #5711
574
574's Avatar
Lol good to know now...
Old 04-25-2013, 01:49 PM
  #5712
armcclure's Avatar
Hmm... That could be the mysterious vac leak I've been fighting for so long... I never got the idle to jump spraying around there though. Don't think I ever pressure tested this setup though.
Old 04-25-2013, 01:53 PM
  #5713
advise's Avatar
Orings on the bodys, now i have more vac, now to figure out my full lean at idle condition
Old 04-25-2013, 02:03 PM
  #5714
South Central *********
JapEatr's Avatar
http://www.******************/forums...ft-tuning.html
Old 04-25-2013, 02:13 PM
  #5715
armcclure's Avatar
Use tinyurl.com for links from rlf
http://tinyurl.com/b8yhmkx
Old 04-25-2013, 02:14 PM
  #5716
JapEatr's Avatar
on a side note: the forum issued me a reward, then took it away just now...wierd
Old 04-25-2013, 02:28 PM
  #5717
advise's Avatar
Same here spayed the injectors with brakeclean nothing
Pulled them and they are all past the cups
Old 04-25-2013, 02:33 PM
  #5718
armcclure's Avatar
Interesting... Anyone happen to have a pair of calipers and an id1k laying around?
Old 04-25-2013, 02:38 PM
  #5719
Rent me! per hour
Area47's Avatar
put the seals on the injector bodies. if you notice the in pic i posed, you will see two green seals. the lighter of the two needs to be in place. your just pissing up a rope.
Old 04-25-2013, 03:38 PM
  #5720
armcclure's Avatar
Right. I was just wondering if any of you knew the dimension of the injector body offhand.
Old 04-25-2013, 03:43 PM
  #5721
zrated89's Avatar
if i would have known that i would have said that was your leak. lol spraying wouldnt find it because the o ring bucket would have sealed it from the carb cleaner hitting it. just get a universal o ring kit they have the size you need. (i actually ran two orings as did taylor)
Old 04-25-2013, 03:45 PM
  #5722
zrated89's Avatar
your full lean, and im in the money with afr's but stfts are reading rich. My idle when the car is warm will drop to 950, but after i drive her and come to a stop will stay at 1250, and not come back down. No leaks anywhere in the system. Im leaning towards a partially stuck open throttle blade
Old 04-28-2013, 01:38 PM
  #5723
LaserblueSS's Avatar
update on my set up: bumped up to a larger meth nozzle (10gph) and put on the smaller 2.75 inch pulley. i gotta say, this thing really wakes up! i can finally hear the TVS whine!!!! and it moves out quite well, and on a pretty conservative tune. i gotta say, i was thinking about swapping to a turbo set up, but i am reconsidering. this TVS is quite fun
Old 04-28-2013, 01:46 PM
  #5724
Melon's Avatar
Can't wait to put on the big boy blower. Glad to hear ur liking the setup laser. Wut mix u running, 50/50?
Old 04-28-2013, 01:50 PM
  #5725
yeah just a 50/50. its the "boost juice" pre-mixed stuff. would there be any advantage to running a different blend? i figured 50/50 is good for more octane AND cooling, instead of just going for higher octane
Quick Reply: Official TVS Thread!!!
