Official TVS Thread!!!
#5712
Hmm... That could be the mysterious vac leak I've been fighting for so long... I never got the idle to jump spraying around there though. Don't think I ever pressure tested this setup though.
#5719
Rent me! per hour
![](https://staticssl.ibsrv.net/autocomm/Content/cobaltss/FCOTM2.png)
put the seals on the injector bodies. if you notice the in pic i posed, you will see two green seals. the lighter of the two needs to be in place. your just pissing up a rope.
#5721
if i would have known that i would have said that was your leak. lol spraying wouldnt find it because the o ring bucket would have sealed it from the carb cleaner hitting it. just get a universal o ring kit they have the size you need. (i actually ran two orings as did taylor)
#5722
your full lean, and im in the money with afr's but stfts are reading rich. My idle when the car is warm will drop to 950, but after i drive her and come to a stop will stay at 1250, and not come back down. No leaks anywhere in the system. Im leaning towards a partially stuck open throttle blade
#5723
update on my set up: bumped up to a larger meth nozzle (10gph) and put on the smaller 2.75 inch pulley. i gotta say, this thing really wakes up! i can finally hear the TVS whine!!!! and it moves out quite well, and on a pretty conservative tune. i gotta say, i was thinking about swapping to a turbo set up, but i am reconsidering. this TVS is quite fun
#5725
yeah just a 50/50. its the "boost juice" pre-mixed stuff. would there be any advantage to running a different blend? i figured 50/50 is good for more octane AND cooling, instead of just going for higher octane
