Official TVS Thread!!!
Old 05-13-2013, 09:31 AM
  #5776
robertmichaels's Avatar
20130513_081442_zps9a6d86ed.jpg?t=1368451676
how do the ID1000's install on the fuel rail? do they not get clipped in like the stock ones or do you remove the purple adapter?
Old 05-13-2013, 11:36 AM
  #5777
Rent me! per hour
Area47's Avatar
they fit just fine. need a small oring the stainless body part to keep it from going through the injector insulator.
Old 05-13-2013, 11:46 AM
  #5778
armcclure's Avatar
with the extra 0-ring holding them up, theyre not going anywhere. toss the clips in a box for someone who loses them.
Old 05-13-2013, 12:07 PM
  #5779
but they are longer than stock, how will the fuel rail bolt in, or do they sit further in the head?
Old 05-13-2013, 01:30 PM
  #5780
Rent me! per hour
Area47's Avatar
they are shorter than the 60's.
Old 05-13-2013, 01:43 PM
  #5781
advise's Avatar
Bryan, turns out comp cut my base circles .021 too big causing valve lift at tdc
Kinda explains why she went full lean at idle randomly
Old 05-13-2013, 01:51 PM
  #5782
armcclure's Avatar
How did it even idle? Yay **** poor compression.
Old 05-13-2013, 02:51 PM
  #5783
mrbelvedere's Avatar
your supposed to release the lifter and set it to half extension for cam installation but I do not know how the base circle on both of the cams comp did for me are 1.180 I just measured a stock cam and it was at 1.180
Old 05-13-2013, 04:50 PM
  #5784
advise's Avatar
Ya But it only hung my #4 open....
Zzp had one set left in stock they measured the same base circle diameter as me and contacted comp
Old 05-13-2013, 05:47 PM
  #5785
Got Bewst?
Bluelightning's Avatar
When did you buy your cams?
Old 05-13-2013, 05:55 PM
  #5786
advise's Avatar
Mid February i believe
If your cams are in I'd do a leak down to see if you have a problem
Mine only made 50psi comp and had 40% leakdown on my #4
And to think I took it to 8k at least 10times
Old 05-13-2013, 06:00 PM
  #5787
Got Bewst?
They aren't in yet but are probably the same batch... I bought them Black Friday and got them in the winter. Fak... I'd better measure these before dropping them in.
Old 05-13-2013, 06:06 PM
  #5788
advise's Avatar
Ya I'd compare them to stock, don't wanna install them and have to redo it all over, buy new cam and crank bolts
I'm not to happy lol
Measure the base circle diameter
Old 05-13-2013, 06:08 PM
  #5789
Got Bewst?
FML. Knowing my luck they're the same. And I was hoping to drive my car this weekend
Old 05-13-2013, 06:14 PM
  #5790
advise's Avatar
If its all together do a comp or leakdown test
Old 05-13-2013, 06:16 PM
  #5791
Got Bewst?
Thankfully it's not. I just have the top end left to assemble actually.
Old 05-13-2013, 10:56 PM
  #5792
Got Bewst?
Mine are out of spec too . But both intake and exhaust are .021" larger. This is gay
Old 05-13-2013, 11:38 PM
  #5793
Blairwolf's Avatar
I just bought a set of S2 cams a month ago and haven't installed them yet. How do i tell if they are out of spec?
Old 05-13-2013, 11:43 PM
  #5794
advise's Avatar
Hey luckly you found out now and not later like me
Guessing why the **** it runs full lean
Old 05-13-2013, 11:56 PM
  #5795
is zzp going to make it right
  #5796
Got Bewst?
Measure the base circle of the cams. Unfortunatley you are probably in the same boat.
Old 05-14-2013, 12:56 AM
  #5797
advise's Avatar
Zzp is helping me out, but it's comps fault, there regrinding the cams for zzp
Called Comp directly also and gave them the sn# and they said its a miss grind
Old 05-14-2013, 02:23 AM
  #5798
What size are you guys seeing and what is it supposed to be? I will have to check mine after work
Old 05-14-2013, 07:17 AM
  #5799
Administrator
Administrator
Staged07SS's Avatar
I bought mine on Black Friday as well, but I have S1.
No issues here, so it must only pertain to the S2 cams.
Sorry to hear about this. At least you guys found the problem though.
Old 05-14-2013, 08:34 AM
  #5800
advise's Avatar
It does suck to have to tear it down, get new hardware and have my tuner come retune me......fail lol
Quick Reply: Official TVS Thread!!!
