Official TVS Thread!!!
#5813
Matt tells you it's an issue advise but sent me this haha.
"We have more cams on order and this was brought to Comp's attention. At 1.201, you would most likely not have any issues. However, it is on the outer edge of reasonable preload in the lash adjusters. If you want to exchange the cams, that is fine."
He may be right but I really don't want to put these in, do a leak down to find out they don't work then have to send them back and waste more time.
#5815
#5821
i am about to pick up a TVS hopefully today. my current engine mods are:
magnaflow 2.5" cat-back
stock air box mod with AEM dryflow filter
zzp shorty header
Vibrant 3" DP w/ highflow cat 2.5" exit
dual pass endplate
zzp stage 3 and stock h/e
custom flow-thru supercharger coolant tank
ottp stage 1 kit*
*60lb Flowmatched Injectors
*2.8" Smoothflow MPS pulley system
*Injector Harness
*Larger Idler Pulley
*NGK 1 Step Colder Copper Plugs
zzp phenolic spacer
meth injection with 8 GPH nozzle and LED activation light 2.5 gallon tank
throttle body spacer tapped for meth injection
WOT box with launch control and 2-step
Trifecta custom tune with adjustable rev limiter
right now i have around 17 psi of boost. what size pulley would be good to run on the TVS? it will come with a 2.6 but i think that might be a little much. i was thinking more like a 2.8 or 2.9. whats the smallest pulley i can run on 60's and 50/50 meth?
zzp shorty header
dual pass endplate
ottp stage 1 kit*
*Injector Harness
zzp phenolic spacer
