Official TVS Thread!!!
Old 05-14-2013, 09:14 AM
  #5801
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by advise
It does suck to have to tear it down, get new hardware and have my tuner come retune me......fail lol
Agreed man. I wouldn't want to do that all over again.
Old 05-14-2013, 09:48 AM
  #5802
574
574's Avatar
Makes me remember back in the day when you got a header and dp (for example) you couldn't wait to get them on and do some wrenching. Now for me it's like arghhhh I have to change a damn BELT! But in reality it's a lot worse than that right now
Old 05-14-2013, 10:09 AM
  #5803
Got Bewst?
Bluelightning's Avatar
Zzp is helping me out, but it's comps fault, there regrinding the cams for zzp
Called Comp directly also and gave them the sn# and they said its a miss grind
Good news, they know. But how long is this gonna take to get rectified? Did they say? I emailed ZZP last night saying I have the same issue as you.
Old 05-14-2013, 10:10 AM
  #5804
Got Bewst?
Originally Posted by robertmichaels
What size are you guys seeing and what is it supposed to be? I will have to check mine after work
Stock is 1.180". Both advise and I have 1.201".
Old 05-14-2013, 10:19 AM
  #5805
robertmichaels's Avatar
mine are bad too, just did a leak down test on #1 and 4. video later today
Old 05-14-2013, 10:26 AM
  #5806
mrbelvedere's Avatar
if the base circle is that far off all the cylinders will be the same not just 1 or 2 cylinders
Old 05-14-2013, 10:27 AM
  #5807
advise's Avatar
Well they had 1 set in stock that was wrong also
They contracted comp and just placed a new order
So they have to be cut, shipped to zzp and then have the hex welded in
Shipped to us
My defective cams just got back to zzp yesterday
Old 05-14-2013, 10:32 AM
  #5808
Got Bewst?
Lets hope it didn't take as long as last time. Took me 3 months to get mine...
Old 05-14-2013, 10:48 AM
  #5809
Shipped to us
I I sent comp 2 blanks 2 hexes and they ground installed hex and delivered in 2 weeks snd I saved quite a bit
Old 05-14-2013, 12:10 PM
  #5810
Madlinx's Avatar
https://www.cobaltss.net/forums/part...oodies-297667/
TVS for sale fellas
Old 05-14-2013, 12:11 PM
  #5811
advise's Avatar
I thought the same but i have 3 heads,
Each had a Different valves open/closed
Seems like depending on the head, valve clearance, and preload
Every head is slightly different In the amount of clearance
Old 05-14-2013, 12:40 PM
  #5812
20130514_082615_zps2231726e.mp4 Video by robertmichaels199 | Photobucket
Video of leak down test
Old 05-14-2013, 12:50 PM
  #5813
Got Bewst?
Matt tells you it's an issue advise but sent me this haha.
"We have more cams on order and this was brought to Comp's attention. At 1.201, you would most likely not have any issues. However, it is on the outer edge of reasonable preload in the lash adjusters. If you want to exchange the cams, that is fine."
He may be right but I really don't want to put these in, do a leak down to find out they don't work then have to send them back and waste more time.
Old 05-14-2013, 01:19 PM
  #5814
yellow dragon's Avatar
Send 'em back!
Old 05-14-2013, 01:28 PM
  #5815
advise's Avatar
Ya but even tho it's a small amount you pay 650, I'd want them to be the exact spec...... that's like getting bearings and saying ehh its .021 off and slapping it together
Old 05-14-2013, 01:48 PM
  #5816
Got Bewst?
Ya exactly. They're definitely goin back. But being in Canuckland it's gonna be atleast $30-$40 to send em back. I asked Matt who's paying the shipping. Hopefully not me.
Old 05-14-2013, 01:50 PM
  #5817
Administrator
Administrator
Staged07SS's Avatar
This.
Old 05-14-2013, 03:16 PM
  #5818
advise's Avatar
I just hope the turn around isn't a terribly long wait
Just spent 4k on full top end rebuild
And she's just in the garage apart
Old 05-14-2013, 03:40 PM
  #5819
Got Bewst?
I'm in the same boat haha. Matt said he figures early next week he should have new ones. I'm gonna fed ex air mine tomorrow.
Old 05-14-2013, 06:14 PM
  #5820
advise's Avatar
Awesome,Can't wait
On a good note I just got my cam and crank bolts from CED Lol
Old 05-15-2013, 02:57 AM
  #5821
06cobalt racer's Avatar
i am about to pick up a TVS hopefully today. my current engine mods are:
magnaflow 2.5" cat-back
stock air box mod with AEM dryflow filter
zzp shorty header
Vibrant 3" DP w/ highflow cat 2.5" exit
dual pass endplate
zzp stage 3 and stock h/e
custom flow-thru supercharger coolant tank
ottp stage 1 kit*
*60lb Flowmatched Injectors
*2.8" Smoothflow MPS pulley system
*Injector Harness
*Larger Idler Pulley
*NGK 1 Step Colder Copper Plugs
zzp phenolic spacer
meth injection with 8 GPH nozzle and LED activation light 2.5 gallon tank
throttle body spacer tapped for meth injection
WOT box with launch control and 2-step
Trifecta custom tune with adjustable rev limiter
right now i have around 17 psi of boost. what size pulley would be good to run on the TVS? it will come with a 2.6 but i think that might be a little much. i was thinking more like a 2.8 or 2.9. whats the smallest pulley i can run on 60's and 50/50 meth?
Old 05-15-2013, 03:05 AM
  #5822
Melon's Avatar
Wut size nozzle(s)? U could run a 2.6.....
Old 05-15-2013, 03:36 AM
  #5823
it is a 8 gph
Old 05-15-2013, 03:39 AM
  #5824
Melon's Avatar
Dual, single? The one to talk to is 100%meth. He can get u set up right
Old 05-15-2013, 03:43 AM
  #5825
sorry single. using the throttle body spacer
Quick Reply: Official TVS Thread!!!
