Official TVS Thread!!!
#6005
So this seems like a good thread to ask in as it has a lot of traffic. When doing the head and timing chain tensioner (possible ati super damper), do u guys recommend changing the water pump as well? And if so what is a good one to change it to
#6007
or pull the front cover and retime everything
Lisle Water Pump Sprkt Holder | Wayfair
#6008
I have to retime anyways though don't I. New head ported with cams and springs/retainers. Does our stock one hold up fine or does it need to b upgraded? Has anyone done this with successful worthy results?
#6012
Plugged up exh? What mods again?
#6013
wp is a mother ****** to change if you leave the cover on you need this tool
I wouldn't mess with the water pump unless there was actually something wrong with it.
#6017
Ya I haven't even put the ATI on yet. Just wanted to drive the car. So it's only gonna get worse before it get better. How I'm seeing way more psi than most with a ported head and catless is beyond me. I'm seeing shy of 30psi and I haven't even wound the car to redline yet...
#6018
#6021
I have it tapped into the vaccum off the intake manifold. It's odd because ever since I put my TVS on its always seemed to read high. Like last year the meth ate away at my cat and almost plugged it solid. Took it the cat out and it made no difference in psi which I found odd.
#6023
Fak I don't wanna pulley up but don't like seeing 30psi lol. Taylor is going to have a look at things when I go down there and then throw on my ATI. He has a 2.9" if I need to go up.
I just now gotta fix my idle issue. It seems to hunt a little and coming off decel back to idle the car will dip down to like 500 rpm. Sometimes recover and sometimes die. When it dies it's a bitch to get started again. Tune related?
