Official TVS Thread!!!
#6265
I have a sony cx-150 HD if we need to use that lol
I wont lie, I absolutely hate the way the option B looks. I cant even stand to see my ugly dual pass plumbing, it seriously bugs the crap out of me :P Besides, when my hose ended its life the other day and all of my IC coolant evacuated the system, it took my probably 10-15 minutes to fill it up and bleed all the air out of the system. Just hptuners commanding the IC pump on and keep filling it up. Stop once in a while to let air come to the top and burp out, then command it on again. Ive done it a time or 6 lol. I just hate cluttered bays, as you can see I deleted my Evap and got rid of all that ugly crap and relocated my boost solenoid as well.
Old Troll still knows how to keep it real
#6272
Was falling about 2 columns before in the higher rpms IIRC, would have to check logs. Didnt get to log last night but should have some time tonight to work with it. I should also add that I slid the bypass valve closer in on the slit mounting holes so the rod is a little tighter so it takes more pressure to open the butterfly when I try by hand. If that makes sense.
#6275
Was fun while it lasted; tune's been dialed in for a few weeks now... 11.0-11.2 AFR on E, 25 psi by 6500
| LA sleeves | balanced\forged rotating assembly 9.5:1 comp. | TVS 2.6 - ATI BALANCER | E85 - 1000cc inj. | supertech 75lb - ported head |
Made a 2nd gear pull, spun, shift to third, car pegs 10.0 and shuts off.
Turn it back on, then this happened cruising @ 65. BOOM! big flame, black cloud, and what sounded like rocks hitting the under side of the car.
Cylinder 3 intake side lifter is split in half
