Official TVS Thread!!!
Old 08-05-2013, 08:16 AM
  #6351
Tjolley's Avatar
Originally Posted by 100% METH
next time we're gonna have fun in the rental white balt :P
canyons, PCH...
epic way to completely destroy an short block.
was funny...
I was undoing the rod end caps, and trevor was poking at me with a long 1/2" extension through one of the windows the rod made. Took me to a sec to realize wtf
Most definetly
Friday night: build the engine and pull the blown engine
Saturday: get the car running by midnight with the new engine and start tuning it. Woop woop
He was tryin to get the socket on the bolts of the broken rod.
So i used a long extention and held thr rod straight.
Old 08-05-2013, 08:58 AM
  #6352
Tennpenn83's Avatar
2.1 TVS Redline
  • 2.1L Ecotec
    • ZZP Girdled LE5 block
    • mrbelvedere sleeves
    • LSJ crank
    • Eagle L61 rods
    • Diamond forged pistons (10.5:1)
    • Level Zero Motorsports balance shaft delete kit
    • ATI SuperDamper
    • GMPP LSJ clutch upgrade
    • LNF shifter bracket
  • Head
    • LSJ head (ported/polished by lsjion)
    • ZZP 82# valve springs
    • ZZP Stage 2 supercharged cams
  • Intake/Exhaust
    • TVS w/2.7" pulley
    • Single pass intake manifold w/flow through tank
    • Stock air intake
    • Injector Dynamics 1000cc injectors
    • DeuschWorks DW300 fuel pump
    • E85
    • ZZP Boost-referenced Fuel Pressure System
    • ZZP phenolic spacer
    • ZZP longtube header
    • ZZP 3" exhaust w/ Magnaflow resonator, Magnaflow muffler
  • Suspension
    • FE5 aluminum arms (upgraded from Redline's stock FE3 steel arms)
    • Powell Raceshop leading Delrin bushings
    • Powell Raceshop trailing spherical bushings
    • PowerGrid Inc Sway bar end links
    • Powell Raceshop Hardcore rear sway bar
    • Centric Cross-drilled/slotted brakes
    • Hawk HPS brake pads
    • Dunlop Direzza Sport Z1 Star Specs (235/40/17)
  • Visual
    • Smoked headlights, front corners and tail lights
    • Competition package wheels
    • Rear spoiler delete
    • Red painted brake calipers
    • Red painted strut bar
    • Polished valve cover
  • Interior
    • B&M Short throw shifter
    • Aeroforce Dual Interceptors (mounted in dual steering column pod)
    • AEM Fuel Pressure, Boost, and Wideband (mounted in triple pod A-pillar cover)
First startup was last night. Has some misfire issues but they seemed to sort themselves out as the motor warmed up. Took it for a shakedown test drive and all else seems sound.
Old 08-05-2013, 09:12 AM
  #6353
Tjolley's Avatar
Almost sounds like the rings gettin seated. U can hear it less and less as the video ends.
Glad to see it back on the road
Old 08-05-2013, 09:14 AM
  #6354
Tennpenn83's Avatar
Thanks buddy. I'm wondering if the battery being dead and the old spark plugs might have anything to do with the misfires. The spark plugs looked good so I reused them, the battery was just useless.
Old 08-05-2013, 09:17 AM
  #6355
Tjolley's Avatar
Hmm the alternator should keep the system voltage up. Just hearing the video sounded like the rings seating. In my mind. It actualy sounded kinda cool sitting there loping.lol
Old 08-05-2013, 09:21 AM
  #6356
574
574's Avatar
Damn that's nice. Great work tenn
Old 08-05-2013, 09:27 AM
  #6357
Tennpenn83's Avatar
It could be that. The car didn't really like to idle either. I will adjust some things in the tune and go back at it.
Thanks buddy! I figured this thread got kind of depressing with Steve's last few posts... Time to lighten up the mood with some good news.
Old 08-05-2013, 10:15 AM
  #6358
Got Bewst?
Bluelightning's Avatar
Great to hear Tenn! Lets get this thread in high gear again. It's been quiet lately.
I should be getting some track and dyno numbers over the next few weeks
Old 08-05-2013, 10:17 AM
  #6359
South Central *********
JapEatr's Avatar
i want to hear how the high compression works out with the 8k rev
Old 08-05-2013, 10:47 AM
  #6360
Tennpenn83's Avatar
I'm anxious to see. I would like to get on the dyno, it's been a long time since I was at one, and that was when I first got the TVS, probably 4 years ago. That was 286whp, 250wtq on a Dynapack dyno. I hope that I easily break into the 400's on this one.
As soon as it's nice and broken in, I'll let you know...
Old 08-05-2013, 12:55 PM
  #6361
InfraRedline's Avatar
Good to hear that Steve is pressing onward with the build!!
I still stand by what I said, that cylinder pressure from power alone didn't bend the rods. Cylinder pressure is however amplified greatly when there is way too much fuel in the cylinders, as everyone knows.
And Ive said it before as well. Going back to discussion on the last 2 pages. If we lost E85 where I live my car would be sold so fast it wouldn't know what hit it. But thats just my take on things.
Old 08-05-2013, 01:07 PM
  #6362
100% METH's Avatar
Question is ...
What caused the sudden flood if that were the case.
The methanol check valve works perfectly
The hg looks good
I need to put some voltage to the denso 1000s to test them.
Old 08-05-2013, 01:13 PM
  #6363
That is the question.
Even if the check valve was bad, the nozzle can only spray so much at X psi of pump pressure.
Old 08-05-2013, 01:22 PM
  #6364
Got Bewst?
If it was the check valve you would have know about it before that happened. The car would have been a donkey loading up at slower speeds before WOT
Old 08-05-2013, 02:17 PM
  #6365
100% METH's Avatar
Oh I know...
was only a tiny 7gph anyway
With the 2.6 pulley,ati and ported head; you could hardly tell it was even spraying.
On another note...
Molnars ordered
MrB sleeves ordered
Diamond 10.5:1 and rings ordered
Moving right along :P
Old 08-05-2013, 02:20 PM
  #6366
100% METH's Avatar
I have the wideband on non stop; I would of caught onto this.
Old 08-05-2013, 02:34 PM
  #6367
Tjolley's Avatar
That and it would affect every cylinder..
Steve i spoke with the failure analysis guy at work that deals with stuff like this and worked for ford for 10+ years
He said eather the injector stuck wide open or a valve hit the piston. Ill call u later about it.
Old 08-05-2013, 02:36 PM
  #6368
mrbelvedere's Avatar
valve would not cause a rod to bend
Old 08-05-2013, 02:41 PM
  #6369
JapEatr's Avatar
does your WB read past 10:1?
Old 08-05-2013, 02:53 PM
  #6370
100% METH's Avatar
No, aem eugo
Old 08-05-2013, 03:16 PM
  #6371
JapEatr's Avatar
probably was like 7.4AFR
Old 08-05-2013, 05:52 PM
  #6372
dwarrick's Avatar
Question about the TVS boost valve.
There is a vacuum line going from the valve to the TVS. The line going from the boost solenoid should go into the valve like the M62, but there is no nipple for it.
Do I have the wrong valve on the TVS or did I screw up the vacuum line routing
Old 08-05-2013, 08:21 PM
  #6373
Powell Race Parts's Avatar
??? actuator has two nipples. The solenoid is beside the rocker cover, has three nipples. lower front to atmosphere; upper front to IM. rear nipple to actuator on TVS. second nipple on TVS actuator goes to blower nipple.
Old 08-05-2013, 08:24 PM
  #6374
^^^ agreed. It hydraulic'd. Prolly cylinder got filled with too much fuel. He saw 10.0 a/f. does the gauge read lower?
Old 08-05-2013, 09:01 PM
  #6375
06blackg85ss's Avatar
should hopefully have some good turbo vs tvs races coming up soon this way
advise.... vs everyone lol.
I think phil (philzoot) gt35r and chris (infe) pte6262 want a piece once the motors are nice and broken in. should be interesting
Quick Reply: Official TVS Thread!!!
