Official TVS Thread!!!
#6351
next time we're gonna have fun in the rental white balt :P
canyons, PCH...
epic way to completely destroy an short block.
was funny...
I was undoing the rod end caps, and trevor was poking at me with a long 1/2" extension through one of the windows the rod made. Took me to a sec to realize wtf
canyons, PCH...
was funny...
Friday night: build the engine and pull the blown engine
Saturday: get the car running by midnight with the new engine and start tuning it. Woop woop
He was tryin to get the socket on the bolts of the broken rod.
So i used a long extention and held thr rod straight.
#6352
2.1 TVS Redline
- 2.1L Ecotec
- ZZP Girdled LE5 block
- mrbelvedere sleeves
- LSJ crank
- Eagle L61 rods
- Diamond forged pistons (10.5:1)
- Level Zero Motorsports balance shaft delete kit
- ATI SuperDamper
- GMPP LSJ clutch upgrade
- LNF shifter bracket
- Head
- LSJ head (ported/polished by lsjion)
- ZZP 82# valve springs
- ZZP Stage 2 supercharged cams
- Intake/Exhaust
- TVS w/2.7" pulley
- Single pass intake manifold w/flow through tank
- Stock air intake
- Injector Dynamics 1000cc injectors
- DeuschWorks DW300 fuel pump
- E85
- ZZP Boost-referenced Fuel Pressure System
- ZZP phenolic spacer
- ZZP longtube header
- ZZP 3" exhaust w/ Magnaflow resonator, Magnaflow muffler
- Suspension
- FE5 aluminum arms (upgraded from Redline's stock FE3 steel arms)
- Powell Raceshop leading Delrin bushings
- Powell Raceshop trailing spherical bushings
- PowerGrid Inc Sway bar end links
- Powell Raceshop Hardcore rear sway bar
- Centric Cross-drilled/slotted brakes
- Hawk HPS brake pads
- Dunlop Direzza Sport Z1 Star Specs (235/40/17)
- Visual
- Smoked headlights, front corners and tail lights
- Competition package wheels
- Rear spoiler delete
- Red painted brake calipers
- Red painted strut bar
- Polished valve cover
- Interior
- B&M Short throw shifter
- Aeroforce Dual Interceptors (mounted in dual steering column pod)
- AEM Fuel Pressure, Boost, and Wideband (mounted in triple pod A-pillar cover)
First startup was last night. Has some misfire issues but they seemed to sort themselves out as the motor warmed up. Took it for a shakedown test drive and all else seems sound.
#6354
Thanks buddy. I'm wondering if the battery being dead and the old spark plugs might have anything to do with the misfires. The spark plugs looked good so I reused them, the battery was just useless.
#6355
Hmm the alternator should keep the system voltage up. Just hearing the video sounded like the rings seating. In my mind. It actualy sounded kinda cool sitting there loping.lol
#6357
Thanks buddy! I figured this thread got kind of depressing with Steve's last few posts... Time to lighten up the mood with some good news.
![Smile](https://www.cobaltss.net/forums/images/smilies/smile.gif)
#6360
As soon as it's nice and broken in, I'll let you know...
![Cool](https://www.cobaltss.net/forums/images/smilies/icon_cool.gif)
#6361
Good to hear that Steve is pressing onward with the build!!
I still stand by what I said, that cylinder pressure from power alone didn't bend the rods. Cylinder pressure is however amplified greatly when there is way too much fuel in the cylinders, as everyone knows.
And Ive said it before as well. Going back to discussion on the last 2 pages. If we lost E85 where I live my car would be sold so fast it wouldn't know what hit it. But thats just my take on things.
#6367
That and it would affect every cylinder..
Steve i spoke with the failure analysis guy at work that deals with stuff like this and worked for ford for 10+ years
He said eather the injector stuck wide open or a valve hit the piston. Ill call u later about it.
#6372
Question about the TVS boost valve.
There is a vacuum line going from the valve to the TVS. The line going from the boost solenoid should go into the valve like the M62, but there is no nipple for it.
Do I have the wrong valve on the TVS or did I screw up the vacuum line routing
