Official TVS Thread!!!
#6702
New problem
Car is breaking up at wot and half throttle, also terrible miss on cold dead cold starts after sitting all night
Interceptor is showing 20+ misfires on # 1 checked the plugs a few days back all looked fine, forgot to do a compression test, going to Test #1 tomorrow
Is it possible that the one coil is weak And getting blow out at medium to high boost?
Also took a fuel sample and its at 80% ethanol
#6708
#6720
gonna make sure all the ends fit etc then I will decide if you or I will cut the hose and assemble. It depends on how successfully I lay it out and figure you will like what I have set up. OR I send all the stuff with bulk hose sufficient for you to a do it. If I do that, I will also send you some vice jaws for the hose; I assume you have a vice. Holding the hose, cutting it correctly and assembling the outer sleeve are the most difficult parts. The black classic hose from Russell really does assemble well. I got tips etc.
I am actually pretty excited about the set up to tell the truth and I squeezed the capacity you want which is much greater than one litre.
And I have decided to send you my sooper dooper 044 mounting bracket i acquired all the way from the UK coz I am such a decent guy lol.... it is blue, as blue is faster, so you will have to bring out the jiggle can for that black scheme of yours....
#6721
