Official TVS Thread!!!
#7019
when you do cams the first thing you decide is how hard you want to spin it then you have the cams ground accordingly then you install the cams and check the center line if its off then you adj it to where it needs to be lock it down
the cam lobe on my cams are so dam big I could not time the engine with stock gears that was the main reason to use adj gears
