Official TVS Thread!!!
#7151
#7160
I might put it back on the other car when I get the motors swapped until it gets cold out for the winter, if my friend doesn't buy it right away! Will be on 80's and a BRFPS on that car tho.
I thought zzp's was 13:1. Your 2.4 is going to be nasty, and steves will be real fun with the giggly. Then he needs to make his trip up here next summer!
#7162
Needs more meth, like 100% meth. None of that gasoline or e85 crap.
I can pick up a 2.6" for my tvs...cheap that's a lot of boost though. I'd want head work as a bare minimum for that
#7163
I said MIGHT! Would be on the 2.7 or 2.9 though until it comes off since my luck I'd run small pulley TVS for 3 years with no problems, put motor in different car, then blow it up right after swapping it And I wouldn't have fueling for a 2.6, or probably even the 2.7. Need to get that car running before anything...problem is the motor is still in my 05 that I am driving lol
#7164
i measured 0.007 taken off the head and had 0.015 takem from the block i have the formula here to calculate the new compression and its like 10.89:1 assuming the head has a stock combustion size.
my car will be on 100% Meth for fuel. fuel cell and second fuel system will be added.
#7165
something like that.
#7171
Sleeves protrude from top of the block 0.015 and you deck the block 0.015 then the sleeves would be at 0.030 protruding...no?
If sleeves were counter sunk @ 0.015 and block was milled down 0.015 then zero deck.
Sorry,
<forever n00b
#7172
i got u now.
the amount the sleeves stick up has to come off anyways.
no the entire block was decked 0.015
