Official TVS Thread!!!
#701
Tell Euthanasia to pick up his phone...
I've been trying to reach him all day... Trying to get an answer on those ARP connecting rod bolts... This process is going through Euthanasia, then being passed on too two other people. The 3rd person being the one who works @ ARP.
I'm ready to order stock connecting rods bolts from CED
#708
I don't know if just putting in 80's will get you what you are looking for. It will bring your IDC way down haha. I would invest in a bigger nozzle if I were you. I was running 20* with a little knock up top with a 10gph. The 14gph made a world of difference through the entire tune.
#711
but i got the beat down last week at the local cruise in, so reliability is being thrown out the window. Tune after tomorrow WILL BE ***** to the wall.
#720
Ran an LS1 camaro last night with full exhaust and MS3 cam. It made 330whp before the cam went in. Did a quick 40 to 100 or so and I spun more than I thought I would lol but still came around him by about a car at 100, but was starting to pull hard when we had to let off. Ill get the video from my friend and post it, and the video of when we can get a cleaner race in!
#723
Any guesstimates on what kind of power I'll be making?
Engine
Should be ready to go in the next week or two.
- Block
- ZZPerformance girdled LE5 block (from 2.4L Ecotec LE5 - 88mm/3.465” bore)
- Stock LSJ crankshaft (86mm/3.386" stroke)
- Eagle 4340 forged steel rods/ARP 2000 bolts (for 2.2 Ecotec L61 - 146mm/5.765" center-to-center length)
- Diamond pistons - custom order (10.5:1 CR)
- Total Seal Gapless rings
- Level Zero Performance balance shaft delete kit
- ATI Superdamper
- Ecotec LSJ oilpan
- New GM OEM thermostat, gears, gaskets, water pump, bearings, chains, chain guides, bolts, seals where applicable
- Total displacement = 2.1L
- Head
- Ported/polished intake/exhaust ports
- Stock valves with 3-angle valve job
- ZZPerformance Stage 2 supercharged cams
- ZZPerformance 82# valve springs
- ARP headstuds
- Ecotec LNF piston oil squirters
- New GM OEM lifters, followers, valve guides, LE5 headgasket, bolts, bearings, gaskets where applicable
- Power Adder
- Harrop HTV 1320 LSJ - Eaton TVS 1320 series rotors
- 2.7" Supercharger pulley
- Air-to-water single-pass intercooler system, electric water pump, added aftermarket flow-through tank
- Phenolic Intake Manifold Spacer
- Exhaust
- ZZPerformance Longtube, equal-length header
- ZZPerformance 3" downpipe w/Magnaflow high-flow cat, Magnaflow resonator
- ZZPerformance 3" cat-back exhaust w/Magnaflow muffler
- AEM UEGO Wideband
- Fuel System
- Stock fuel pump
- ZZPerformance Boost-Referenced Fuel Pressure System
- Stock fuel lines
- Injector Dynamics ID1000 - 1000cc fuel injectors
- E85
![](http://i20.photobucket.com/albums/b224/azn_ladie82/2012-06-01_21-01-48_287.jpg)
