Official TVS Thread!!!
Old 10-24-2013, 10:15 AM
  #7301
574
574's Avatar
and Mr B's fasteners. You MUST get those.
I need to invest in these this winter
Old 10-24-2013, 11:06 AM
  #7302
ThexGovenor's Avatar
Originally Posted by mrbelvedere
yo gov are you in virgina
Yes I am in Virginia at Fort Lee. why?
Old 10-24-2013, 11:43 AM
  #7303
nhanson's Avatar
I no longer own a TVS
Boo!
Old 10-24-2013, 12:17 PM
  #7304
InfraRedline's Avatar
Technically all I have right now for power adders are 2 M62's And one car with no motor in it and one thats 2 hours away from having no motor in it lol
The TVS is still in my trunk for the time being though But it's paid for, along with the header and DP.
Old 10-24-2013, 12:38 PM
  #7305
nhanson's Avatar
Dual M62 on 1 car
Old 10-24-2013, 12:43 PM
  #7306
Originally Posted by nhanson
Dual M62 on 1 car
My God...its brilliant!
The TVS and header will be installed on my friend's car soon. We are in the process of putting his GMPP clutch in, but when we bench bled the TOB it spewed fluid everywhere as soon as it got any pressure in it, so Tom at CED overnighted another TOB yesterday, and it showed up this morning, so we will try that one tonight. As always CED delivers!
Old 10-24-2013, 12:45 PM
  #7307
mrbelvedere's Avatar
pm zrated on here he is in virginia
Old 10-24-2013, 02:38 PM
  #7308
Just did, lets see what he says
Old 10-25-2013, 01:43 AM
  #7309
RooTBeeR's Avatar
dual m62's with xmas tree ports?
Old 10-25-2013, 09:21 AM
  #7310
Starting to wonder if his car is ever getting the TVS put on. Got the new replacement TOB and we put it in and hooked the line up to the dist. block on the trans and gave the pedal literally 2 pumps and it leaked straight out of the TOB and down the trans. The first one at least held some pressure. This one just continued to leak. Gonna try one more, but I am considering throwing my old LSJ one in there since it always worked for me.
Got my old header and dp on his car though, just need to weld a vband on to the catback.
Old 10-25-2013, 09:57 AM
  #7311
armcclure's Avatar
Did you reuse the clutch pipe...
Old 10-25-2013, 10:05 AM
  #7312
Brand new clutch pipe. Used the same procedure I used for my car and a friend's car.
Old 10-25-2013, 11:20 AM
  #7313
South Central *********
JapEatr's Avatar
check o ring on top of clutch pipe
Old 10-25-2013, 11:29 AM
  #7314
New O-ring is on. It seems to come out of the TOB itself. He said it barely starts to move, then just spits out fluid. I was there the first time, but left before he started to bleed it last night. Put his old TOB in and it will start to build pressure and not leak, but his old one has a ton of miles and is why we took it apart in the first place. The pedal didn't have much pressure and was getting worse, and he could barely get into gear, so he ordered the new clutch kit.
Old 10-25-2013, 11:52 AM
  #7315
JapEatr's Avatar
i think he may have another issue as well. check the clutch line as well
Old 10-25-2013, 11:58 AM
  #7316
Its weird because another local redline is having the same issues he was, where after a pull it would get hard to shift and the pedal would lose pressure and go almost to the floor before starting to disengage the clutch. Bled both cars over and over with no positive results. Both cars added more power and the deterioration was happening quicker. We finally decided to do a clutch on my friend's because his 2 second shift times weren't helping anyone and he didn't want to grenade the trans shifting with a clutch that wouldn't disengage. Now we are here lol
Old 10-25-2013, 01:07 PM
  #7317
armcclure's Avatar
From now on I'm testing and filling tob's before install. I've had some issues with the last couple cars I've done as well.
Old 10-25-2013, 09:57 PM
  #7318
Tjolley's Avatar
So some good news and bad news
Good first.
I was able to temporarily get my TOB to hold.
Bad news
I blew the HG again.
Meny meny pulles with a Tvs 2.6 + 150 shot + 28° of timing.
Last pull i hurd a loud pop and the car bucked at 135mph. Get off the road and the bottom of my car is covered in coolant.
Try to add some it just comes out every which place it can around the head.l
AAA towing me home might have more picks tonight.
Srry for the Shitty pics
Old 10-25-2013, 11:21 PM
  #7319
armcclure's Avatar
Hey... Um... I have a rough guess as to how this happened...
Old 10-25-2013, 11:42 PM
  #7320
you need to wash that ******
Old 10-25-2013, 11:52 PM
  #7321
Tjolley's Avatar
That is all the that stuck to the coolant on the bottom of the car.
Old 10-26-2013, 09:04 AM
  #7322
maybe stick to a 100 shot next time
Old 10-26-2013, 09:24 AM
  #7323
Tjolley's Avatar
100 shot per cylinder??? Ok sounds like a plan
Old 10-26-2013, 09:52 AM
  #7324
Got Bewst?
Bluelightning's Avatar
Sooooo you still want those cams?
Old 10-26-2013, 03:04 PM
  #7325
nhanson's Avatar
Do you ever underbody wash? Lol
Quick Reply: Official TVS Thread!!!
