Official TVS Thread!!!
#51
I think that would be more then enough. If your base is 58 then your actual FP under boost should should be about 78-80psi which Should be plenty. If you have to run it that high to get enough fuel then upgrading your pump would be a good idea.
I would recommend starting at a base of 50psi. That is where I plan on starting...I guess we will see. I want to take a long drive just to get this dino fuel out of my tank!
just disconnected the line on the rail and jump out the relay lol
#52
I replaced the stock 05 pump with the Walbro - running 2.7", E85, but went BRFS instead of RSFS.
#59
depends if i switch fuel systems or not. if i go with 190s and a dual pump setup then yes i'll stay turbo cause then i'll be able to run about 35-40psi on alcohol. which would be 650+ if not 700. but if i keep the current setup then i'll debate on going with the lysholm at 500-550..
550sc>591tc.
550sc>591tc.
