Official TVS Thread!!!
Old 11-12-2013, 02:35 PM
  #7501
InfraRedline's Avatar
Originally Posted by advise
Can you make you intake with a 3.5 maf housing
I'm tired of my car going rich when I hit the last cell
A 3.5" maf housing is a good way to keep a handle on things, but you lose some low end resolution. Will it be noticeable? Probably not too bad. It doesn't need to go rich with the 3" though. Just kind of have to "massage" the PE table a bit in the upper range. I'm sure Paul knows how to do that. He may not want too though, as it isn't really the best way to do things.
Old 11-12-2013, 02:36 PM
  #7502
armcclure's Avatar
Don't worry about low end resolution. Maf only isn't the only way.
Old 11-12-2013, 04:03 PM
  #7503
advise's Avatar
He recommended a maf translator
I mean does it pull hard all the way to 8k
I'd just rather have full maf control instead of guessing
Old 11-12-2013, 04:47 PM
  #7504
Josh@ottp's Avatar
I could make a 3.5" intake. I think it would require a little grinding on the car to open up the hole to behind the headlight.
Old 11-12-2013, 06:01 PM
  #7505
Don't worry about low end resolution. Maf only is t the only way.
Just stating it. Agreed though. I have a 3.5" MAF housing for next year, so in no way am I steering him away from it.
If you are right on that border line and don't want to run on the last cell then a 3.5" maf housing should get you the control you want.
I forgot the cobalt has that. The redlines are wide open down there lol
Old 11-12-2013, 07:02 PM
  #7506
TStone's Avatar
Put the maf right before the throttle body. No intake. Let 'er eat!!
Old 11-12-2013, 07:56 PM
  #7507
Tjolley's Avatar
I might take u up on this very soon josh.
Old 11-14-2013, 10:47 AM
  #7508
Beat up on my old TVS last night with my M62 Might be a different story tonight. I'll make a thread and link the vid in a bit.
Old 11-14-2013, 11:28 AM
  #7509
https://www.cobaltss.net/forums/war-...5/#post7199669
Old 11-14-2013, 04:13 PM
  #7510
Mendomar06's Avatar
Anyone have a definitive answer on what I need to change so I can run E85
Old 11-14-2013, 04:17 PM
  #7511
TStone's Avatar
Tune for sure. And injectors, depending on what you have right now
Old 11-14-2013, 04:19 PM
  #7512
What is your setup now? Basically need 80# injectors and a tune. Depending on the TVS pulley size you'll need a BRFPS as well.
Old 11-14-2013, 05:46 PM
  #7513
Mendomar06's Avatar
I'm aware I need a tune. My setup is 3" intake, 2.6 pulley, TVS, #80s, ZZP longtube headers and DP, option b, dual pass. My question was mostly because I've "heard" you need a new fuel pump and fuel lines, is that true if so what should I use.
Old 11-14-2013, 06:45 PM
  #7514
What year is your car? You will need a BRFPS at a minimum. Possibly larger than 80# injectors on a 2.6
Old 11-14-2013, 06:53 PM
  #7515
Josh@ottp's Avatar
I can set you up with a fuel system. 80's would be fine for e85. You will need a new pump though.
Old 11-14-2013, 09:27 PM
  #7516
Mendomar06's Avatar
Ok post a link or something so I can check it out
Old 11-14-2013, 09:55 PM
  #7517
574
574's Avatar
I've seen under most occasions only 2005 pumps need replaced when running E
Old 11-15-2013, 12:52 AM
  #7518
Mendomar06's Avatar
Really?
Old 11-15-2013, 08:14 AM
  #7519
574
574's Avatar
Or if you are out of pump you replace with a higher flowing one. But 2005 pumps have been known to fail on E
Old 11-15-2013, 09:49 AM
  #7520
04-05 pumps like to just fail out of random it seems. Especially when you are 400 miles from home. Makes for an interesting random parking lot walbro install...
Old 11-15-2013, 11:10 AM
  #7521
Mendomar06's Avatar
Haha, well mines an 06 so I think I'll replace it, or should I go do that recall on it?
Old 11-15-2013, 11:14 AM
  #7522
Got Bewst?
Bluelightning's Avatar
The 06 and up pumps are better
Old 11-15-2013, 11:25 AM
  #7523
Mendomar06's Avatar
How long would it truly last on E though? The car has 86k miles on it
Old 11-15-2013, 11:29 AM
  #7524
Got Bewst?
Let er eat and find out
Old 11-15-2013, 11:46 AM
  #7525
Mendomar06's Avatar
I guess that's a good plan lol
Quick Reply: Official TVS Thread!!!
