Official TVS Thread!!!
#7653
Price is less... their stage 2 cam is about on par with my zzp stage 3.
Supercharged cams
S1 204/210 @ .050" .423"/.423" lift 111 LSA
S2 210/216 @ .050" .423"/.440" lift 113 LSA
S3 216/222 @ .050" .440"/.456" lift 114 LSA
S4 222/222 @ .050" .456"/.456" lift 114 LSA
Turbo cams
TS1 210/204 @ .050" .423"/.423" lift 113 LSA
TS2 216/210 @ .050" .440"/.423" lift 114 LSA
Supercharged cams
Turbo cams
#7655
my intake cam is .456 222@50 exh is .453 224@50
without putting a degree wheel on the s4 its hard to tell I could have a faster rate of lift then they or not my cams may have a bigger lobe then theirs to many variables in play but like I said above it all needs checked piston to valve and centerline and if the centerline is off then it needs adj and the hex retimed no cam is is 100&% plug and play if you want the most out of it
#7658
there is basically one camshaft outfit left in america its comp cams. its possible to have custom grinds made, and Mr. Belvedere did just that.
as for testing the only vendor on here tests engine stuff like that is ZZP. Its an interesting dynamic, just copying modifying and throwing stuff out there without testing just as Bluelightening has suggested. I wonder what Rudy at FMSR has tested.
does rudy have a dyno cell? we know ott doesnt. LIke it or not, it comes to ZZP have and do test a lot. The cams i buy from ZZP for our customers check out 100% everytime.
The only thing I do for engines is stuff that is either engineered or developed through OEM Channels. Most of it is lsj stuff from long ago. Our PCV stuff is new and evolving and I said at the get go, the science is right , but the customers are basically part of a pretty large field test program.... and the customer response has been very good and the individual reports very well thought out. Smart guys modding these cars.
The Cobalt scene is changing and its interesting to draw a comparison about vendors and the folks doing business with the members here, to the new goldfish in the fish bowl that think the ***** cat looking at them licking his lips is a cuddly friendly creature.
#7660
#7663
the only track times and records zzp have is on their stage 3 cams and a turbo grind nothing more so that point is basically useless and all of zzp sc grinds are comp turbo grinds with a few changes like I said I would not be one bit afraid to buy comps cams from ottp comp is good at what they do
#7664
I never said anything about steering away from OTTPs cams. I just mentioned about testing them. Your cams aren't just drop in and go. OTTPs S4's are similar to yours so how any people will just drop them in and go thinking that's what they are? Probably a lot. Nothing says otherwise.
Who knows maybe they are. Time will tell.
#7667
https://www.cobaltss.net/forums/08-1...ml#post7206983
For engines, ZZP do more than any other vendor on here with first hand R&D not just plucking numbers ou t of the air and having it made. They have more experience I suggest than you do. It comes down to the number of experienced people and the sheer volume of work they do. I have worked on their conversions to cure issues, and there was nothing wrong at all with their builds, very well done. Issues with things like failed PCM or failed parts are just the way of life with a car.
I am not a nutswinger for ZZP. Its just clearly fair to give credit where credit is due and to review the facts.
I dont have a road wheel dyno, and based on what I see, I wont ever get one. Do you? NO. You surely have access to one, as do I, but thats a big difference to doing it in house.
equipment + expertise + a lot of money= r&d. I bet you JW DO NOT have the money to put into as much R&D as Zoomer and his crew have into engines.
Heck, I bet NO ONE on here as done as much track work R&D as I have with Cobalt /Delta.
It may come as a shock to people, once they have built their cars mods and all, that there is now an equal amount of time and money or more, that has to be spent to make that modded car a sucessful completed project.
Some vendors here dont have one engine in house to check and develop parts on, let alone an inventory of different ones. ZZP have box cars full of engines.
#7668
just another silly comment JW . read this
comp cams just don't pull numbers out of their asses to grind cams they have more time and money spent into designing and grinding cams then anyone and they know what works and I would say that is why zzp went to them just because it dose not have the zzp or john powell stamped on it dose not make it untrust worthy junk
I like zzp they have some awesome stuff but there are more choices then just them
#7669
I posted info on stage 2 cams and said what the torque curve was,I said the customer waas happy but I ddint like the results, and you crapped all over what i said.
sooner or later, you have to wonder. that vendor with the fancy cams has a track record of picking numbers out of his ass and then putting them up for sale. ZZP do the grunt work.
I strongly dislike cams for an LSJ and this is the TVS thread, I have a TVS and I have experience with both hot cams and stock cams. I make my choice, I advice customers as I feel, and then do whatever they ask.
changing the lsa for driveability is common practice. lift and duration higher and longer the more difficult it becomes. Comp cams are pretty much the only game in town. so not a lot new here.
like you say you cant just pop them in unless someone does the pre fits. ZZP do that for everything I buy from them. I dont have the same confidence in other vendors. If I was to buy your cams from you I would be confident that you would do the prefit work. its all a question of who you beleive and the track record and background.
No vendors as far as I know have posted dyno sheets on long tube headers. I have done that work on my own.
just as i rated springs for the suspension.
#7670
but still just putting the hex in in the correct location dose not mean that you are installing the cams on the correct centerline they can still be off either way and if they are and you need to move the cam then that can throw the hex out of time and then you will need to decide if your willing to sacrifice some power loss or take the time and retime the hex so in all reality no cam is 100% drop in and run if done correctly
as for changing the centerline for drivability is not common practice that i know of i change it to change power delivery and cylinder pressure and just because you have more lift and duration doesn't mean it will be harder to drive
as for selling cams i don't sell cams i just had my own custom ground for me and the power delivery i wanted if you drove my car you would want the cams i have it drives better then a stock cammed engine
#7671
For the record, I will say that mrB's car runs and drives like an amplified stock car. Incrediy smooth. The cams don't "hit" as you would expect from something that large. It's just a nice smooth ever increasing pull.
#7673
"we know you don't like nothing but stock cams and that is fine and dandy but there are some of us who want more then what stock cams will give you. as for the vendor with the fancy cams and the magical numbers pulled from his ass i would say that they relied on the cam grinders mountain of experience to give the direction they needed to go in
as for selling cams i don't sell cams i just had my own custom ground for me and the power delivery i wanted if you drove my car you would want the cams i have it drives better then a stock cammed engine"
^^^ exactly Mr. B, we are in violent agreement. Except the part where you said I would want your cams. But never say never.....
#7674
