Official TVS Thread!!!
Old 12-24-2013, 09:05 PM
  #7976
Tjolley's Avatar
Originally Posted by mrbelvedere
im gonna have to call bull **** on that one
I hope my gauge isn't wrong. The engine bay is now noticeably cooler.
Old 12-25-2013, 08:10 PM
  #7977
armcclure's Avatar
Because of an oil cooler? Holy placebo batman.
Old 12-25-2013, 08:24 PM
  #7978
TStone's Avatar
Old 12-25-2013, 09:05 PM
  #7979
South Central *********
JapEatr's Avatar
Lsj already has an oil cooler ???
Old 12-25-2013, 09:14 PM
  #7980
mrbelvedere's Avatar
yes it dose but it sucks removing the stock one and replacing it with one mounted out front dose wonders for engine temp and oil temp control
Old 12-25-2013, 10:09 PM
  #7981
Powell Race Parts's Avatar
merry christmas Mr. B.
agreed.
Old 12-25-2013, 10:11 PM
  #7982
the nice thing about an oil to water cooler integrated into the cooling system, is the function of the cooling system part. once you accept that, the stock LSJ cooler (and the LNF one for that matter) is a pretty decent piece. We never needed to put an extra cooler or change the engine oil cooler on the race cobalts. We did make a trans oil cooler...
Old 12-25-2013, 10:37 PM
  #7983
it is a decent piece but its one of those things that can be made better and removing it off of the coolant system lets the cooling system do its job easier I did a setup for a guy you know john and it fixed a lot of his temp problems
Old 12-25-2013, 10:47 PM
  #7984
noorj's Avatar
what should oil temps be? about the same as coolant or is slightly higher normal?
Old 12-26-2013, 12:10 AM
  #7985
depends on oil dino burn off is lower then syn but 180 to 220 is reasonable but the stock system is also for emmissions also the quicker the oil heats up the less fuel is used if you keep the oil temps down the less burn off you get
putting the oil cooler of the engine coolant helps under a hard pull my engine temps will pull back to 168
Old 12-26-2013, 12:22 AM
  #7986
Tjolley's Avatar
so wat is there a problem with my guage or wat.
all i know is that wen i put the 2.4 in with out a oil cooler id see 220+ oil temps after driving the car around moderately hard. keep in mind that its 40-50° during the day right now and 20-30° at night.
with the cooler installed my oil stayed around 180.
and my engine bay seems cooler after idleing around
wat would cauz the change in temp? cuz u guys r sayin BS im open to learn
Old 12-26-2013, 07:12 AM
  #7987
Tjolley's Avatar
also wats wrong with keeping a stable oil temp
Old 12-26-2013, 08:12 AM
  #7988
armcclure's Avatar
http://www.motorweek.org/features/go...ge/oil_coolers
Old 12-26-2013, 08:32 AM
  #7989
Tjolley's Avatar
hmm only thing i see there is they mention u want the oil around 212 to boil off moisture, but it also needs to be right for the tstat in the engine. i believe ours is eather 180 or 185. thats y i picked the 180 oil tstat
Old 12-26-2013, 08:58 AM
  #7990
armcclure's Avatar
I'm just offering info.
Old 12-26-2013, 09:10 AM
  #7991
Tjolley's Avatar
thanks man.
i just want these guys to tell me y running this big of a oil cooler is a problem. i purposely used a oil thermostat to keep temps stable.
its like putting a bigger radiator on ur car while u still run a thermostat.
i did it for the efficence.
http://www.mobil.com/AP-English-LCW/...ce-of-oil.aspx
Old 12-26-2013, 09:28 AM
  #7992
you chose what you chose for showing off nothing more thats your style but in the end its yours
Old 12-26-2013, 09:39 AM
  #7993
Tjolley's Avatar
well u saying bs to me seing a difference in oil temps with and with out the cooler
Old 12-26-2013, 10:27 AM
  #7994
Originally Posted by Tjolley
thanks man.
Importance of Oil | Mobil™ Asia Pacific
if you were that worried about the efficiency of the oil cooler then you would know that the size of the cooler is based off of oil capacity hp level and so on bigger is not better a simple search or a couple phone calls could have told you that
Oil Cooler Design Basics | How to add an oil cooler to a car
I talked to canton and derale and they both came up with the size im running but they said it may be a hair to big but to let the car warm up a little longer before driving and it would be fine the t stat kits I found were not in a -10 line size so I did not run one due to that
I was saying bs to under hood temps 180 is 180 not matter the size of oil cooler
Old 12-26-2013, 10:41 AM
  #7995
Tjolley's Avatar
i did a lot of research and found that a oversized cooler isnt a problem if ur running a oil thermostat.
i was refering to the fact of having a oil cooler on the car made it seem way cooler in the engine bay.
ill put together some tests to prove it. using temp sensor on verious points in the engine bay loging it with HPT to prove my point.
Old 12-26-2013, 11:19 AM
  #7996
you don't need a heavy equipment oil cooler on a 4 cyl its overkill show boating
Old 12-26-2013, 11:23 AM
  #7997
Tjolley's Avatar
call it wat u want. i understand that its over kill but wat is the problem with the size.
its a Setrab cooler.
Old 12-26-2013, 11:27 AM
  #7998
lol I called it nothing but what it is and that is your style so
Old 12-27-2013, 06:24 PM
  #7999
ThexGovenor's Avatar
Think I fixed my idle surge issue. Lots of good info over on RLF for tuning!
Old 12-27-2013, 09:09 PM
  #8000
100% METH's Avatar
Yup
Cam thread does wonders
Quick Reply: Official TVS Thread!!!
