Official TVS Thread!!!
Old 06-06-2012, 10:27 PM
  #801
advise's Avatar
Originally Posted by kdub1492
Hey guys just picked up the AIS meth kit from Advice, I'm on TVS with 2.9, what size nozzle should I run with it? And is there anything else I should pick up. Its the trunk mount kit
Id say a 7 to 10
Try the 7 I sent you
Might be too small tho
But it all depends on your mix if water meth
I always used a 75/25 with the m62 worked great
Old 06-06-2012, 10:28 PM
  #802
kdub1492's Avatar
Originally Posted by advise
Id say a 7 to 10
75 water 25 meth?
Old 06-06-2012, 10:34 PM
  #803
TStone's Avatar
75 water 25 meth?
other way. 75 meth 25 water
Old 06-06-2012, 11:22 PM
  #804
G11
G11's Avatar
Definetly gonna get a Meth kit lol
Old 06-06-2012, 11:57 PM
  #805
100% METH's Avatar
You will need more than 10gph at 23 psi with a 75/25 meth to water mix
Old 06-07-2012, 12:06 AM
  #806
advise's Avatar
what iat2 are you guys seeing at the end off a pull just did a 3rd gear before
hit 25 psi with a top of 140 iat2
and dropped down to 20* above ambient temp in about 10 seconds
Old 06-07-2012, 12:39 AM
  #807
100% METH's Avatar
Put it to you this way...
We were able to do back to back pulls on a completely stock intercooler system @ 28 psi
4th gear pulls ending @ 125-135* on the dyno on a 75* morning
on a cool 50-60* night on the road we saw sub 120 @ 7400 in 3rd
Old 06-07-2012, 12:49 AM
  #808
advise's Avatar
with water meth?
Old 06-07-2012, 12:50 AM
  #809
100% METH's Avatar
yessir
the ultimate cooling mod (50/50)
Old 06-07-2012, 12:52 AM
  #810
advise's Avatar
gotcha
i mean it cools down great with my dual pass,h/e,euthanasia flow thru tank
but i feel like 140 is a little scary
when does the computer pull timing 160?
Old 06-07-2012, 01:30 AM
  #811
Got Bewst?
Bluelightning's Avatar
140* isn't terrible. I believe with HPT you can set the computer up for whenever you want it to start pull timing. I see 125* with my 2.8" but also running a 14gph nozzle. Honestly, invest in a phenolic spacer. For $100 it's a great cooling mod.
Old 06-07-2012, 01:45 AM
  #812
RooTBeeR's Avatar
my **** must be wrong then...mine sees 160* even with he car stock on dual pass and opt-b
Old 06-07-2012, 03:19 AM
  #813
advise's Avatar
have one lol
Old 06-07-2012, 08:26 AM
  #814
zrated89's Avatar
guys 80# injectors with harness for sale only about 500 miles on the 80s. Will sell with harness for 160 shipped lmk
Old 06-07-2012, 09:09 AM
  #815
LaserblueSS's Avatar
anyone know if the AIS nozzle or Devils own nozzle will fit on the AEM injector? are nozzles a universal kinda thing? hoping so cause according to you guys i need to get a bigger nozzle ASAP if i plan on upping the power.
Old 06-07-2012, 09:36 AM
  #816
574
574's Avatar
Maybe your pump is out?
Old 06-07-2012, 09:47 AM
  #817
RooTBeeR's Avatar
nope, when pump went out, cruising would hold 180 and a pull would hit 210-220
Old 06-07-2012, 09:51 AM
  #818
574
574's Avatar
dayummmmm haha
Old 06-07-2012, 10:13 AM
  #819
USA Y U NO HAVE AUTOBAHN?
tylerjclance's Avatar
my activity is low
that's actually my rank, wtf? LOL The battles thing..
Last edited by tylerjclance; 06-07-2012 at 10:13 AM. Reason: Automerged Doublepost
Old 06-07-2012, 10:23 AM
  #820
Administrator
Administrator
Staged07SS's Avatar
Damn....
I wouldn't have even tried a pull.
Props to you for tryin it out though man
Old 06-07-2012, 11:25 AM
  #821
06blackg85ss's Avatar
gotcha
stars dropping timing over 160, cuts boost at 190. 140 isn't too horrible for a blower car especially at the boost level you run (higher compression more heat etc). I see 156 on my car m62 2.7 pulley stock he and dual pass.
Old 06-07-2012, 11:53 AM
  #822
TStone's Avatar
Yes! Nozzles are universal. I got the AEm kit and An AIS nozzle
Old 06-07-2012, 12:06 PM
  #823
zrated89's Avatar
Yea man like a said on a hot day at the track with an iat2 of 134 at the tree ill see 164 at the trap
Old 06-07-2012, 12:13 PM
  #824
100% METH's Avatar
Euthanasia still makes those 1 gallon under the hood tank you could fill with ice.
Old 06-07-2012, 12:23 PM
  #825
zrated89's Avatar
I was considering that whats he charge? Can't ice the option b tank. I'm going to do something like that with a setup to run the ic pump and cooling fans in tye staging lanes ive never done any of that small stuff lol. Prolly would have been 11s all day if i did lol
Quick Reply: Official TVS Thread!!!
