Official TVS Thread!!!
Old 04-16-2014, 02:34 PM
  #8476
armcclure's Avatar
Inb4mrBsezwedontheatsoak
Old 04-17-2014, 02:00 AM
  #8477
ThexGovenor's Avatar
13.5 on street tires is good work. no driver mod needed
I cant tell if you are making fun of me right now
Old 04-17-2014, 10:46 AM
  #8478
Hockeyman's Avatar
m62 time right there
Old 04-17-2014, 01:01 PM
  #8479
*looks down with shame* it was my first time at the strip
Old 04-17-2014, 01:14 PM
  #8480
Powell Race Parts's Avatar
comon guys anthing below 14 secs with these fwd turkeys at the strip for a first timer is good. fwd was not made for drag racing. duh
Old 04-17-2014, 01:17 PM
  #8481
Administrator
Administrator
Staged07SS's Avatar
Old 04-17-2014, 01:44 PM
  #8482
InfraRedline's Avatar
I like turkey.
Old 04-17-2014, 03:19 PM
  #8483
Hockeyman's Avatar
gobble gobble
Old 04-17-2014, 09:55 PM
  #8484
armcclure's Avatar
Fwd turkey lmao
Old 04-19-2014, 02:45 AM
  #8485
KTM
KTM's Avatar
Injectors and HPTuners have been ordered, Need a clutch before I put TVS on. Starting to slip pretty bad, If I get GMPP clutch, should I get the flywheel too?
Reason I ask is, if I have to get the flywheel also I will have to wait until next Friday to order it, otherwise I can order it now.
I will have clutch put in as soon as it comes in, so sooner I order it sooner I can start with TVS.
Old 04-19-2014, 03:37 AM
  #8486
Just get your stock wheel resurfaced.
Old 04-20-2014, 12:22 AM
  #8487
Haven07's Avatar
Question for tvs guys on e85, what fuel pump are you guys running? I'm leaning toward the AEM e85 Fuel pump that zzp sells but would like some more input.
Old 04-20-2014, 06:16 PM
  #8488
advise's Avatar
Got my mini afc dialed in by my tuner
Picked up massive power up top
Full maf control changed the car
Old 04-20-2014, 08:33 PM
  #8489
gibsonj4's Avatar
How are the IDCs with 60#s and a 2.9 pulley? Should you go 72s for a 2.9"?
Old 04-20-2014, 11:55 PM
  #8490
SSfamilywagon's Avatar
Most are on stock or Dw300 but finding the Dw300 isn't sufficient for the bigger build guys.
On gas or e85? On e85 my 80's on 2.9 see 105 idc at 75k
Old 04-21-2014, 12:07 AM
  #8491
Haven07's Avatar
After some digging I think I'ma go with the walbro 450 lph e85 pump
This is the link I came across
Radium Engineering - Tech Articles
Old 04-21-2014, 08:50 AM
  #8492
MaxDugas's Avatar
Hey guys, was curious if anyone here would know where to get a seal changed on a TVS? Maybe a rebuild too, the snout seal where is the pulley blowed and all the oil leaked, the thing is that the supercharger have less than 2000miles.
Old 04-21-2014, 07:56 PM
  #8493
100% METH's Avatar
contact ZZP
they compeltely rebuilt mine for $200
Old 04-21-2014, 07:58 PM
  #8494
gibsonj4's Avatar
Gas. No E in my area of FL.
Old 04-21-2014, 10:45 PM
  #8495
cavfiredesire's Avatar
Curious..
Where is the best place to spray your meth with one of these? Im under the impression we cant sprat pre tb like the m62
Old 04-21-2014, 11:26 PM
  #8496
Got Bewst?
Bluelightning's Avatar
Sure you can. I ran a TB spacer when I sprayed meth.
Old 04-21-2014, 11:38 PM
  #8497
mrbelvedere's Avatar
you can spray pre tp if you want it will not hurt a thing
Old 04-22-2014, 12:25 AM
  #8498
Spray it post tb anyways though lol, better yet into the manifold
Old 04-22-2014, 01:47 AM
  #8499
100% METH's Avatar
Here's 4 reasons why this isn't a good idea vs one PRO
  • Less fluid dispersion between the four cylinders
  • Nozzle is under a vacuum; if the check valve or solenoid fails, this can cause catastrophic failure.
  • Your not cooling the blower; this is key w/ a roots
  • Difficult to reach without removing S/C to clean filter media within nozzle.
PRO(s):
  • It cools alright (For greater results see above)
Old 04-22-2014, 05:05 PM
  #8500
advise's Avatar
Saturday is judgement day
Going on the rollers
Previous dyno of 328/282 on stock motor
Tvs 2.7 pulley about 26psi weather dependent
e85
full bolt ons And full cooling mods (besides meth)
New stuff
Cnc m2 race head
.5mm o.s intake valves
.5mm o.s iconel exhaust valves
75# dual coil springs
Stage 2 s/c cams
Neutral balance shafts
Arp head studs
Id1000s
Mini afc
8k Redline
And a solid tune thanks to paul
Quick Reply: Official TVS Thread!!!
