Official TVS Thread!!!
#8485
Injectors and HPTuners have been ordered, Need a clutch before I put TVS on. Starting to slip pretty bad, If I get GMPP clutch, should I get the flywheel too?
Reason I ask is, if I have to get the flywheel also I will have to wait until next Friday to order it, otherwise I can order it now.
I will have clutch put in as soon as it comes in, so sooner I order it sooner I can start with TVS.
#8491
This is the link I came across
Radium Engineering - Tech Articles
#8492
Hey guys, was curious if anyone here would know where to get a seal changed on a TVS? Maybe a rebuild too, the snout seal where is the pulley blowed and all the oil leaked, the thing is that the supercharger have less than 2000miles.
#8499
Here's 4 reasons why this isn't a good idea vs one PRO
PRO(s):
- Less fluid dispersion between the four cylinders
- Nozzle is under a vacuum; if the check valve or solenoid fails, this can cause catastrophic failure.
- Your not cooling the blower; this is key w/ a roots
- Difficult to reach without removing S/C to clean filter media within nozzle.
PRO(s):
- It cools alright (For greater results see above)
#8500
Saturday is judgement day
Going on the rollers
Previous dyno of 328/282 on stock motor
Tvs 2.7 pulley about 26psi weather dependent
e85
full bolt ons And full cooling mods (besides meth)
New stuff
Cnc m2 race head
.5mm o.s intake valves
.5mm o.s iconel exhaust valves
75# dual coil springs
Stage 2 s/c cams
Neutral balance shafts
Arp head studs
Id1000s
Mini afc
8k Redline
And a solid tune thanks to paul
e85
New stuff
Cnc m2 race head
Stage 2 s/c cams
Arp head studs
Id1000s
Mini afc
8k Redline
