Official TVS Thread!!!
Old 04-27-2014, 06:18 PM
  #8576
advise's Avatar
Originally Posted by 06blackg85ss
You Hit 108% Last Pull btw. And the stage 2 cams worked fine. Held power nice to 8k no drop off
**** didn't see that, was all hyped being on the dyno
Old 04-27-2014, 06:38 PM
  #8577
yellowsupercharged06's Avatar
The torque was fallin hard after 7k tho ... He shuld shift at 7.5 to keep that torque up
Old 04-27-2014, 06:44 PM
  #8578
mrbelvedere's Avatar
they went flat around 7200 the zzp cams are decent but there are better choices cheaper
you don't shift when the tq falls of you shift the hp drops out
Old 04-27-2014, 08:11 PM
  #8579
06blackg85ss's Avatar
not saying there isn't. but it didn't tank over which isn't bad either.
Old 04-28-2014, 02:26 PM
  #8580
Rent me! per hour
Area47's Avatar
you use the timing files i sent ya?
Old 04-28-2014, 02:44 PM
  #8581
InfraRedline's Avatar
Nice runs Advise. Same torque and 5more whp than my old TVS setup. I know how fun it is
Old 04-28-2014, 03:05 PM
  #8582
it was pretty close to what he was running already. Car wouldn't take more than 22.5 degrees up top though. I have that thing setup pretty aggressive. 11.9-12.0 afr and peak of 27 degrees tappering to 22.5 up top (was seeing kr for some reason with any more)
Old 04-28-2014, 04:01 PM
  #8583
100% METH's Avatar
Paul did you load a timing map with a 19-20* midrange ascending to 22.5 by redline?
You could of prob hit it a little higher on the top end if you didn't bring so much timing in in the mid range.
Old 04-28-2014, 04:16 PM
  #8584
The dyno was deff off , i dynoed 267/239 on full bolt ons/e85/2.8 and m62 ... Which we all know is really low. Im running Pauls tune as well.
I may have some more dyno time lined up this weekend at a dif shop (one that isnt operated by a crack head) so hopefully we get some more ligit #s
Old 04-28-2014, 04:28 PM
  #8585
100% METH's Avatar
It's a dyno, how is it off?
The dyno you'll be attending next will throw out lesser or greater numbers, does that make it wrong?
Old 04-28-2014, 04:30 PM
  #8586
TStone's Avatar
Weird how everyone blames the dyno when they don't get the numbers they want
Old 04-28-2014, 04:34 PM
  #8587
noorj's Avatar
this
Old 04-28-2014, 04:35 PM
  #8588
not a matter of right or wrong ... but more accurate.
Old 04-28-2014, 04:36 PM
  #8589
100% METH's Avatar
Dyno is a tool used to measure progression
This isn't a matter of accuracy
Old 04-28-2014, 04:37 PM
  #8590
i mean of course your guna be pissed if your expecting to put down X-amount and everyone else with the same setup puts down X-amount (my case lol) but if you get a happy dyno and you put down 15 more than expected your going to beat your chest and run around like the peoples champ.
i guess it goes both ways ... ohh well it is what it is
Old 04-28-2014, 04:38 PM
  #8591
totally agree but everyone is about those peak #'s
Old 04-28-2014, 08:05 PM
  #8592
Eh judging by my dealings with that shop in the past. They haven't been very consistsnt. Dynod my rx7 there one time put down 383whp. Few weeks later went back for a dyno day and it put down 307whp. Needless to say I use one place now that's been consistant. But either or its just numbers. Get the cars to the track and see what they trap then we will know.
Old 04-28-2014, 11:33 PM
  #8593
100% METH's Avatar
Did you attempt multiple maps to see if 25-27* in the midrange was actually beneficial?
Old 04-29-2014, 06:59 AM
  #8594
I wasn't there, so no, just the street tunes that on the car. Wifi wasn't working at the shop so I couldn't send them anything else to try. James's car is setup like that though, I think anthony's hits a little harder timing wise at wot.
Old 04-30-2014, 08:13 AM
  #8595
RooTBeeR's Avatar
Damn that TVS was screaming
Old 04-30-2014, 03:07 PM
  #8596
car definitely moves out. waiting patiently for him to run it down the track
Old 04-30-2014, 05:05 PM
  #8597
advise's Avatar
Meth/retune
Then track time
Old 04-30-2014, 06:18 PM
  #8598
Sounds like a plan to me
Old 04-30-2014, 08:17 PM
  #8599
100% METH's Avatar
Somebody say meth
Old 04-30-2014, 08:42 PM
  #8600
Lol you should see the setup we run on my buddies vettes. One is a total of 52gph 100% meth. And the other is approx 30gph both on alky control progressive setups. So weird to pull fuel out of the sd tune as boost goes up
Quick Reply: Official TVS Thread!!!
