Official TVS Thread!!!
Old 05-12-2014, 06:43 PM
  #8626
Soul Reaper's Avatar
At what point with E85 and a TVS does the stock fuel system need to be upgraded? if So what should be upgraded? (06 IRL) Also What pulley should be used when shooting for 325whp with full supporting mods?
Old 05-13-2014, 02:19 AM
  #8627
ThexGovenor's Avatar
2.8 pulley. and just upgrade the pump and injectors.
Old 05-13-2014, 10:02 AM
  #8628
InfraRedline's Avatar
If you are shooting for 325whp, a 2.9 pulley, 80# injectors and a stock pump will do the trick on E85. You will start to max the 80's on the stock fuel system if you push farther than that, but a BRFPS or RSFS will cure that.
Old 05-13-2014, 11:00 AM
  #8629
100% METH's Avatar
He will be really close to the limitations of the fuel system if he revs that 2.9 out on e85
Better to just take the hit on torque and just run a aftermarket 3.15" pulley (provided harrop tvs pulley has had tendencies to oval the bolt holes when in use)
Old 05-13-2014, 11:31 AM
  #8630
KTM
KTM's Avatar
What's the smallest pulley I can run with 60lb injectors.
Old 05-13-2014, 11:39 AM
  #8631
mrbelvedere's Avatar
on gas 3.15 not enough inj for e85
Old 05-13-2014, 12:03 PM
  #8632
I'll be honest, when I first got the TVS I planned to run the stock 3.15" pulley for a while before going to the 2.9, and I put it on and did a few pulls and have never been so disappoint with my car in my life. I felt so bad about my purchase of the TVS that I wish I didn't buy it at that point. The car felt no faster than the 2.7 M62. The next day I put the 2.9 on and it restored quite a bit of my faith in it. Then we all know the story after that lol.
Riding near the limitation of the fuel system shouldn't scare anyone, I pushed right at 100% IDC on the 2.9 and 80's at 7500 rpms on my car and my friends car that bought my TVS for a while with commanded fueling up top. They are cheap injectors, but they aren't terrible quality, and can perform just fine when being pushed a bit. With that being said, I didn't feel comfortable running them on the 2.9 with the ported head on stock fuel system, but I had new injectors already anyways.
Old 05-14-2014, 02:24 AM
  #8633
SSfamilywagon's Avatar
^^^ I'll agree with that. Can't be to afraid to push it a little.
Our car has been fine for over a year on the 2.9, 80's, e85 revving to 75k seeing over 100% idc
Would I wanna do it forever, nope. Either cap your rev limit or get a Brfps
Old 05-14-2014, 07:34 AM
  #8634
100% METH's Avatar
Not my car to be recommending 100% + idc
Old 05-19-2014, 11:17 PM
  #8635
Dave1515's Avatar
I am considering getting a TVS. I have no access to e85 and don't have a desire to run meth. That being said is it even worth it money/hp wise to get a TVS ?? Worth it if I were to upgrade cams and port the head?? I have full bolt ons and cooling mods... Just interested in hearing peoples thoughts.
Old 05-19-2014, 11:45 PM
  #8636
Got Bewst?
Bluelightning's Avatar
Depends on your hp goals. TVS with a stock motor on pump gas is good for around 300whp.
Old 05-20-2014, 08:48 AM
  #8637
armcclure's Avatar
Yep. So if you want a nice easy 300 and smooth power delivery that's not beating the ***** off your engine, go for it!
Old 05-20-2014, 09:24 AM
  #8638
KTM
KTM's Avatar
Haven't read much on meth yet. Is it hard to set up and use? Getting option b, duel pass and a heat exchanger this weekend. Might do meth next pay, not sure yet. Don't have access to e85 in my area.
Old 05-20-2014, 12:15 PM
  #8639
Got Bewst?
Not hard to set up or use. But you will have to get tuned for it.
Old 05-20-2014, 12:18 PM
  #8640
KTM
KTM's Avatar
Would you recommend it. I could get before I take the car to get tuned.
Old 05-20-2014, 12:29 PM
  #8641
Got Bewst?
Well I ran meth injection for 4 years with my M62 and TVS. It does work really well if you don't have access to E85. The problem I did was I got a little greedy with it spraying larger amounts. Last year the line pulled off the pick up line of my meth and took my motor down. But I was spraying so much that the car relied on it. So if you choose to spray meth, just done tune it so the car relies on it and you can catch it if you ever have an issue.
Old 05-20-2014, 01:02 PM
  #8642
KTM
KTM's Avatar
I'll look into it. Which kit do you recommend?
Old 05-20-2014, 01:06 PM
  #8643
Got Bewst?
I ran a Devilsown stage 1 kit. Was a good bang for the buck.
Old 05-20-2014, 01:08 PM
  #8644
KTM
KTM's Avatar
Does ottp sell it? I've got everything but my exhaust there. Josh said he will give a discount if I buy multiple things at once since I got TVS in group buy.
Old 05-20-2014, 01:32 PM
  #8645
Josh@ottp's Avatar
I have 2 of them in stock.
Old 05-20-2014, 01:35 PM
  #8646
I would have to disagree with that ive seen in the 320s
Old 05-20-2014, 01:38 PM
  #8647
armcclure's Avatar
There's 2 ways you can go with meth. Either run it small enough that you have time to **** down f it fails, or run it so heavy that the car will jut fall over if it fails. As if your fuel pump went out.
Old 05-20-2014, 01:41 PM
  #8648
Got Bewst?
And I've seen less than 300whp. That's why I said around
Old 05-20-2014, 03:01 PM
  #8649
KTM
KTM's Avatar
I'll probably order it this weekend. Just ordered theTVS pulley and intake from you last weekend.
Old 05-20-2014, 03:42 PM
  #8650
that's a big around
Quick Reply: Official TVS Thread!!!
