Official TVS Thread!!!
Old 06-18-2014, 08:34 PM
  #8751
SSfamilywagon's Avatar
Yes i think you can get away with it.
We're on a 2.9 seeing 105% idc by 7500 rpm using e85 and made 341
I'd give the 2.7 a shot on your 1k's. If idc are high, just pulley up a to 2.8.
If I had an Ls4 tb, that make up the 9 hp needed for 350. You need to rev the TVS though. It was a 10 hp difference forgoing from 6500 to 7500
Old 06-18-2014, 09:20 PM
  #8752
gibsonj4's Avatar
Originally Posted by Empty Pockets
hmm, i was trying to avoid any head work at the moment due to funds. Could i get away with a 2.7 and 1000s with no BRFPS and still hit 350+WHP? From what i was reading i was under the impression i would need a further fuel mod besides injectors such as a BRFPS or a return style system
I'm in a similar situation. I have an 05 LSJ with a TVS on a 2.9 and 80s. My goals are only 320-330whp which is plenty for a daily for me. I was going to swap pumps for e85 and keep the 2.9. If I decide to pulley down to a 2.7 I'd go with the BRFPS or return style system.
Old 06-18-2014, 09:30 PM
  #8753
Empty Pockets's Avatar
wouldnt the problem be needing larger injectors and not a new pump or BRFPS..? I thought 80s on E85 maxed out on a 2.9 pulley
Old 06-19-2014, 12:23 AM
  #8754
South Central *********
JapEatr's Avatar
just purchased a tvs and 1000cc injectors... maybe you can figure out who i bought them from
heres the goal: 350-375whp on E85
Ive been trying to do some research on what pulley size and fuel mods i will need to achieve this (i already have all the basic bolt ons; intake, header, dp, exhaust, dual pass, s3 heat exchanger, etc...)
The tvs has a 2.6 on it currently, do i just need to buy a zzp BRFPS?
Guess where that came from
Old 06-19-2014, 01:33 AM
  #8755
Yes 80's, 2.9 on stock fuel system is maxed out. I'm doing a return/boost reference system now and can stretch my 80's a little further for a 2.7. I'll let you know my idc's soon
Old 06-19-2014, 01:36 AM
  #8756
are you running stock clutch? What about axles?
Old 06-19-2014, 01:41 AM
  #8757
Gmmp clutch, stock axles, Powell stg 1 rotated mount with LNF rear and upper mount
Old 06-19-2014, 01:48 AM
  #8758
nice, was really looking at getting the gmpp, but was curious how it would hold up to the power
Old 06-19-2014, 01:52 AM
  #8759
More then enough for the TVS. Its even holding up fine on the turbo guys
Old 06-19-2014, 01:59 AM
  #8760
good to know, def next on my list of things to buy!
Old 06-19-2014, 02:15 AM
  #8761
JapEatr's Avatar
We are running a gmpp clutch on taintedred07s build and he should make over 600whp
My gmpp is flawless with 400wheel plus spray
Old 06-19-2014, 02:35 AM
  #8762
wow thats really impressive from a sub $300 clutch
Old 06-19-2014, 06:34 AM
  #8763
Powell Race Parts's Avatar
Mantic Performance Clutch Kit Mantic Performance Clutches
read this. exedy do a stage 2 for the F23 very inexpensive and is rated around 300 wheel torque. under rated. GMPP is similar. just like these outrageous claims for transmission orque capacity from vendors who should know better, throwing out numbers just sucks people in....
Old 06-19-2014, 08:33 AM
  #8764
gibsonj4's Avatar
So would you go with 1000s then? I'm trying to figure out what pump to go with because the 05s pumps are weaker . However, I've read the AEM e85 pump is a good choice but it's a pain in the ass to make it fit as is the walboro 255 in the 05s
Old 06-19-2014, 08:59 AM
  #8765
JapEatr's Avatar
Wally 450 and a dremel
Old 06-19-2014, 10:49 AM
  #8766
Hockeyman's Avatar
ready to install my wally
Old 06-19-2014, 11:27 AM
  #8767
Like mentioned above. If going e85 do Wally 450 and trim a little, all the pumps need trimming anyway.
I did the DW300 and it needed a little trim. But Jape here already maxed that pump out.
I'd do 1k's inj but my build plans call for more injector.
1k's, return style with good pump base pressure turned up on a built head TVS motor should get you around the 400whp mark with small pulley. More if you keep the pulley big
Old 06-19-2014, 12:22 PM
  #8768
InfraRedline's Avatar
My friend is running my old TVS on a 2.7 and my old 1k's on the stock fuel system and stock 04 pump and he has fuel up to his 7400 rpm redline. Going to put in his AEM pump soon, but the stock one has held up so far.
Old 06-19-2014, 12:54 PM
  #8769
gibsonj4's Avatar
Gotcha. I need to get a clutch before I want any more power ha
Old 06-19-2014, 12:56 PM
  #8770
advise's Avatar
1ks dw300 rsfs
Holds a extremely ported head and cams at around 95% idc at a 50 psi base on a 2.7
Old 06-19-2014, 12:57 PM
  #8771
Yup there ya go. This guy knows
Old 06-19-2014, 01:25 PM
  #8772
I ran my stock clutch on the TVS and 2.7 and a ported head for a year with no issues. Swapped it out just because GMPP's are cheap and I like doing 7k launches on slicks at the track lol
Old 06-19-2014, 01:35 PM
  #8773
Originally Posted by advise
1ks dw300 rsfs
How high you revving it?
My buddy and I need to invest in some slicks and do this HAHA. What kind and size were you running Taylor?
Old 06-19-2014, 02:18 PM
  #8774
I had a set of Hoosier QTP cheater slicks, 26x9.5 on a 16" wheel. I now have 24.5x8.5 MT slicks on a 15" wheel. Only got to use the full slicks once though, on a bad track day last year. Lots of fun the few times I've used them on the street though
Old 06-19-2014, 02:19 PM
  #8775
JapEatr's Avatar
yes
Quick Reply: Official TVS Thread!!!
