Official TVS Thread!!!
Old 08-06-2012, 03:44 PM
  #1226
TStone's Avatar
LSJ's don't make torque anyways.. who cares..
SC LSJ's**
Old 08-06-2012, 04:00 PM
  #1227
100% METH's Avatar
they make torque it's just very linear
290-300 ft lbs is pretty good for a 2900 lb FWD car
Your setup believe it or not is making that torque wise, plus/minus depending on which dyno you use. Not that it really matters though
Old 08-06-2012, 04:04 PM
  #1228
TStone's Avatar
Then why doesn't it do wheelies?
Old 08-06-2012, 04:05 PM
  #1229
100% METH's Avatar
because your not in reverse :P
Old 08-06-2012, 04:06 PM
  #1230
TStone's Avatar
Well ****.. i'm doing it wrong then!
Old 08-06-2012, 05:07 PM
  #1231
carstedt's Avatar
ya i plan on taking it to the dyno once im back and then when im back in WI for good i plan on trailering the car down to him and lettin him hav his fun playing around with different tunes seeing which 1 comes out the best
Old 08-06-2012, 05:59 PM
  #1232
advise's Avatar
Need some help with my build
Ported head by you know who
Zzp 82# springs
Stock valves
Zzp stage 2 cams
Zzp nbs
New valve seals
1000cc injectors
Ati balancer
Head studs
Stock bottom end
2.7 pulley
E85
So should i pulley up to save my lower end
To like a 2.9
With a 2.7 the blowers going a Little over 20,000 rpm
Looking to keep it around 25psi
Old 08-06-2012, 06:23 PM
  #1233
TStone's Avatar
Zzp 82# springs
Stock valves
Zzp stage 2 cams
Zzp nbs
New valve seals
1000cc injectors
Ati balancer
Head studs
Stock bottom end
2.7 pulley
E85
To like a 2.9
I'd prolly say go to a 2.9.....
Unless... unlesssssss.. you wanna drown it with meth and go with a 2.6..
Old 08-06-2012, 06:29 PM
  #1234
carstedt's Avatar
dont drown it in meth especially on e85 its not even really needed more cooling than fueling..a 2.8 with the balancer would b the same as a 2.7 u have on now..i say 2.8 w/o drowning in meth lik the kid said
Old 08-06-2012, 06:50 PM
  #1235
TStone's Avatar
It's needed if he wanted to go with a 2.6..
Old 08-06-2012, 06:57 PM
  #1236
carstedt's Avatar
hes on e85 its not really needed i could take my meth off and be fine and im the equivalent to a 2.5...he doesnt hav many cooling mods but e85 will do the job not ever1 beats the **** outta their cars constantly and keep high temps..he doesnt need to drown the **** in meth
Old 08-06-2012, 07:11 PM
  #1237
TStone's Avatar
& run like 15*...
Old 08-06-2012, 07:22 PM
  #1238
carstedt's Avatar
were u beaten as a child? 15* on a full e85 tune?
Old 08-06-2012, 07:29 PM
  #1239
carstedt's Avatar
Not a clue man
I've never played with your head combination on the dyno
straight from ZZPs site:
-The Stage 2 cams are the next step, they will raise your powerband about 700-1000rpm, they will make peak power around 7500-7800rpm! They will require neutral balance shafts.
If I were to guess your peaking torque around 5k... Aside from flow, the way James sculpts your timing table will play a role.
Hit up the dyno and have James find out for you; he would get to experiment a bit and show you the different curves which can be created at different cylinder pressures.
The great thing about e-85 is you can really take advantage of it's near limitless ability to advance timing how ever you like on your well flowing head combination using a 2.6 TVS pulley @ 10:1 Comp.
not saying ur goona run infinate amount but its goona be more than 15*
Old 08-06-2012, 07:30 PM
  #1240
Chevycobaltss3's Avatar
Funny when people think they know what there talking about lol.
  #1241
TStone's Avatar
You couldn't have the tune anywhere close to what you could have it with meth in the mix.. & it'd be really beneficial since on a 2.6, he'll be reving it to about 8k
Old 08-06-2012, 07:40 PM
  #1242
carstedt's Avatar
idk y u speak sumtimes...udk my car or how its tuned or nething...the meth is for straight cooling its only a 50/50 mix..ive ran it w/o it before and it felt the exact same..y tell him to drown it when hes goona be on e85..a single 7gph would be enough on a 50/50 as well if he really wants meth but its not needed
Old 08-06-2012, 07:48 PM
  #1243
TTR Powered
Team SS's Avatar
Or worse, When they believe it too.
Old 08-06-2012, 08:41 PM
  #1244
100% METH's Avatar
I think the point Tyler is trying to get across is the heat caused by the 2.6 could be subdued with the right jetting. 7gph using 50/50 would do diddly squat on a 2.6 setup listed above. Use 100% distilled water and you'll begin seeing a change.
It's amazing how much timing you could get away with on just e-85 alone. I've spoken with some tuners who have reported as much as 30* advance before they decided enough was enough.
Give him time he'll learn; ****... 5 years ago I didn't even know what a spark plug was and was fully content with my 05 corolla S around town.
Old 08-06-2012, 08:44 PM
  #1245
carstedt's Avatar
im not sayin im a expert nor do i ever claim to be 1..ive learned alot from u and james but ik bullshit when i see it..and tellin him to drown it in meth is dumb if hes on e85 already..could the heat go down? yes but is it needed? no cuz in all honestly idt its goona get that high especially for ppl who DD their car and not race it much at all
Old 08-07-2012, 12:22 PM
  #1246
ebristol's Avatar
You need to be a lot more specific. 30* where? With what setup?
I know it is "fun" to throw stuff like this out there but there are other people reading this thread who don't have a clue what they are talking about and are going to run around telling people "they know they can run 30* of timing on E85." So try to be a little more careful.
I run 50* of timing on E85 is anyone is interested. Under cruise...
Old 08-07-2012, 12:53 PM
  #1247
RooTBeeR's Avatar
I knew that was coming
Old 08-07-2012, 01:58 PM
  #1248
zrated89's Avatar
I'm keeping my meth system and running straight distilled water on e85 but what do i know ?
Old 08-07-2012, 02:00 PM
  #1249
carstedt's Avatar
i only run 50/50 with mine but switchin to 2 5gph nozzles instead of a single 7
Old 08-07-2012, 07:46 PM
  #1250
RooTBeeR's Avatar
Im installing a meth kit with an M2 nozzle for 100% water
to use inside the car to spray me for a misting system.
Quick Reply: Official TVS Thread!!!
