Official TVS Thread!!!
Old 08-31-2012, 11:57 AM
  #1726
Joe Schulte's Avatar
Just monitoring the progress.
Old 08-31-2012, 12:32 PM
  #1727
zrated89's Avatar
She's getting there I'm having track withdrawls now that I'm driving her again tho
Old 08-31-2012, 05:22 PM
  #1728
InfraRedline's Avatar
Raising the idle doesn't fix the issue either...it just makes the car louder when it's struggling
Old 08-31-2012, 07:31 PM
  #1729
armcclure's Avatar
Well i just dropped my scalar down to 2750 from 5000 and it surged back and forth from 1500-2500 and swung up to over 4 a couple times. That def didn't work lol
Old 08-31-2012, 07:37 PM
  #1730
TStone's Avatar
lmao maybe you should have went to like 1500, try that
Old 09-01-2012, 02:19 PM
  #1731
Rent me! per hour
Area47's Avatar
Is that the reason that you just less than halved the cylinder volume sir?
new, easier the ecm to control them, plus the ifr table maxing out at 63.5 didn't fair very well with them. paul yaw and i spent 2 weeks going back and forth with information to get the tables right for the lsj ecm. the final outcome is magical when tuned right. when the afr varies .1 +/- indicated 1.0/14.7 while idling and cruising with the trims enabled. i think it's a good thing.
Originally Posted by mrbelvedere
the cams you ran were stock the blue printed aspect of it just ensures that they were of stock lift and duration
im not going to argue about what you think you know about what my motor had in it. my information about said cams comes from a much better source. if you think there isn't cheating in scca, you're sadly mistaken.
Old 09-02-2012, 01:59 PM
  #1732
zrated89's Avatar
new wideband o2 ordered, and a new meth nozzle. Gonna keep the iat2s in check again. With the E85 she pulls her ass of but the iats showed higher due to not running my meth system
Old 09-03-2012, 08:41 PM
  #1733
armcclure's Avatar
i did the same thing, yet the tables we came up with vary a bit from yours. when i tried your base file, it did not make any change to my idle issue at all. also, wth is up with the offset table? the difference between what paul and i came up with and your base was mainly that foc scaling, i used flow rate vs volts and you used cyl vol; and the offset table on yours isn't even close to the offset values for the injectors regardless of pcm.
is that odd offset one of the things that helps?
Old 09-04-2012, 11:07 PM
  #1734
Rent me! per hour
Area47's Avatar
i don't ever recall sending you a base 98lb tune.
i have only done 4 1k cars, and im pretty sure i know each one of em.
Old 09-05-2012, 08:15 AM
  #1735
armcclure's Avatar
You emailed it to me a few months ago... After I'd asked for help with my high idle issue in your fb group.
Old 09-05-2012, 08:18 AM
  #1736
zrated89's Avatar
weird my issue is with the throttle body staying cracked open an acting like there is a vacuum leak. I even disconnected the intake and with key on engine off the throttle plate looks like its not sitting in the fully closed position. Wideband o2 should be here today and we will try some things to fix the idle
Old 09-05-2012, 12:28 PM
  #1737
Fidget's Avatar
I had my TVS installed yesterday with a 2.7 pulley and on a humid day ended up getting 293WHP and 255TQ. I am happy with the results and I would imagine on a cooler dryer day i would hit over 300WHP which was my goal.
Old 09-05-2012, 12:30 PM
  #1738
Got Bewst?
Bluelightning's Avatar
Are you spaying meth?
Old 09-05-2012, 12:33 PM
  #1739
Fidget's Avatar
No running a Griffin with option b and 94 Octane fuel.
Old 09-05-2012, 01:00 PM
  #1740
ebristol's Avatar
That is honestly not that bad considering your mods and the weather.
Old 09-05-2012, 01:20 PM
  #1741
GRABBER BLUE MUSTANG GT
Corvettespirit's Avatar
checking in!!!!
Old 09-05-2012, 01:22 PM
  #1742
carstedt's Avatar
uve been gone for quite sum time
Old 09-05-2012, 01:29 PM
  #1743
jonathan923's Avatar
hes been saving up for a turbo kit
Old 09-05-2012, 01:34 PM
  #1744
carstedt's Avatar
screw a turbo kit i lik my TVS lol i dont plan on keepin this car long neways
Old 09-05-2012, 01:39 PM
  #1745
Fidget's Avatar
I also have 173,000 miles on the car as well. So Ya im pretty happy with the numbers.
Old 09-05-2012, 01:40 PM
  #1746
Fidget's Avatar
Old 09-05-2012, 01:50 PM
  #1747
zrated89's Avatar
Originally Posted by Corvettespirit
checking in!!!!
u can check in after mines dialed in on the rollers and in the 11's
Old 09-05-2012, 08:05 PM
  #1748
RLY?
Old 09-05-2012, 08:09 PM
  #1749
that was the plan Jonathan!
Old 09-05-2012, 08:54 PM
  #1750
574
574's Avatar
Do I smell a part out in the future??
Quick Reply: Official TVS Thread!!!
