Oil Catch Can
Oil Catch Can
Is it actually worth it?..I made my own today and its similier to the one i had on my srt4...it only costs 17 bux and its a simple 20min install...I do have a How-to,but dont want to post it up until i see some responses or something and where to connect it to make sure it was done right..I connected mine via the line that goes into the intake pipe,and i usually find some oil inside the intake/around throttle body after cpl of days,so i decided to make it
It's probably worth it. LS1's use them to prevent oil sludge build up on the throttle body blade.
Would you mind posting up the how-to? Did you use an air/oil separator for an air compressor and then spliced it in between the valve cover and intake piping?
sure did..will post how-to in the morning wit pics
importkiller
09-30-2015 07:18 PM
