Oil filter relocator!!!
THAT little thing? YEAH OK! It gets no air flow that would help cool the oil worth a crap! My M3 oil temps would creep up into the mid 300's when I beat on the car hard and I'm damn sure a supercharged/ turbocharged 4cylinder would do the same if not worse! I'm talking about putting an oil cooler out in front of the radiator or in an area that allows for air flowing directly over it to cool the oil down. Now that said if you get the kits designed for an oil cooler they have a by-pass port that doesn't open up till the oil reaches its operating temperature and will close so its doesn't "over cool" the oil. But when you beat on the car, like I'm sure 9 out of 10 SC owners do, then the oil is allowed to flow thru the cooler dropping the temps. And none of the oil coolers I've ever run have caused a drop in presure only a drop in oil temps.
So to re-cap. A bypass valve to keep the oil from flowing to the cooler when its cold, and no it doesn't cause a drop in presure. Well unless you have a leak or did something wrong to cause a blockage in the system but thats not the coolers fault, it'd be instalation error.
Pressure drop happens in any system when you add more length of hose and fittings, radiators, whatever. It may not be much, but it happens. I'm saying, on these cars, the costs would far outweigh the gains. I've never seen any ecotec have an oiling issue, bearing faliure, anything. Run good oil, change it regularly (3000 miles or less if you drive hard), and you will never have a problem.
Don't say anything, wait until someone posts pics of that done
The Hamburger Perf 3322 oil filter relocatin kit DOES NOT fit the ECO.
Its got 18x1.5 filter threads.....thats for the PF46 or PF47 stlye oil filter that the QUAD4 and the 2.2 OHV take..... the threads on our oil cap are more like 50x3 or something ridiculous.....the picture doesnt make it look wrong, it IS wrong, LOL
It has coolant running through it, it's not air cooled. Oil temps on these cars are not bad at all. M3's are higher revving and higher compression, leaner burning too. Not suprised that they get hotter, it's more of a performance engine.
*shrug* Whatever. I'm from the school of thought that if you can improve upon a system then go for it. If you guys are happy with the stock setup who am I to tell you differently. Like I said I've never experenced any drop in presure from running a remote setup on any of the cars I've used them on. My FireBird, Camaro's, and finaly on the M. But its true I've only done it on 7 different cars so I guess the 8th could have had an issue.
i could be wrong, but since the ecotec has about 5445435 extra plugs in the oil system, could you not just remove one of the high pressure ones, run that down to a traditional style cooler, then run it back into one of the lower pressure fittings?
#36
IDK the M doesn't have any kind of forced induction like these little things have. To me they should actualy get hotter.
#37
the only reason i brought this up is because a while back i remembered a thread about people complaining of the stock filter location. so i came across this kit and thought i'ld post it up as a means for them to move the filter where ever they sought fit. not as a means to add extra oil/cooling to our systems.
#39
Unfortunately it is mislabeled. I bought a cheap knockoff of the hamburger relocator and this is what the bottom looks like. It is for a spin on filter.
Same as the pick on the right which does show the bottom
This is a bigger deal for us guys with Atom's because the filter is behind the firewall right behind the seats and a pain to reach. Here is the custom filter relocator and upgraded cooler for the Atom
#41
An oil relocator kit serves several functions beyound just relocating the filter. It adds at least 1 to 2 qts of oil to the system, allows the oil a chance to leave the engine there-by adding in the cooling of the oil which makes it last longer and helps cool the internal parts of the engine. Adding an oil cooler to this would be an AWESOME aditional mod as it would add more oil and allow the oil temps to drop even further to help cool the engine more. Trust me if they ever do come up with one that fits the ECOTEC motor it would a better mod then some of the crap I've seen around here.
The LSJ already has an oil-cooler. Not a "true" oil cooler, as some would proclaim; It's a cooler that is piped with coolant. A water-to-oil-cooler, if you will.
importkiller
09-30-2015 07:18 PM
