Oil Smells Like Gasoline
what about the gas smell in the oil? will this make ur car loose power the white smoke and gas smell in the oil if its the piston rings? and what causes this to happen? sorry but im new to this whole thing
The reason for the white smoke is the oil slung up by the piston (to keep the sleeve walls lubricated) will get past the ring on the down stroke, and durrng combustion it will burn with whats left of the air/gas mix. When the oil burns it creates a white/blue smoke.
Causes for compression loss and ring failure are being rough on your engine for an extended period of time, adding boost (excess compression that the ring can not take), metal slivers in the oil, running the car hot.....normaly just beating on your motor
I've been working for GM for a few years now and it seems like to me that higher performance cars sometimes get a gas smell in the oil. Be it a corvette or any SS model from time to time when you drain the oil there is a smell of gas and the cars all run great.
I checked for any Bulletins for you and I could't find any. But like everyone else told you, if there is any other color smoke than black coming out of the exhaust when the engine is hot, then you have a serious problem ..... probably rings
Well good luck with that! Hopefully they will fix it right this time, right, LoL
#36
I'd beat the ***** off of it ..... then if there is really something wrong it will show up a lot faster ... just what I would personally do
#37
hmmmmm...well, thats one way.....or you could just pull out your wang, slap the dealer in the face with it, and tell them to try again!
#38
#39
Quick Update...
White smoke is getting worse. Warm day today (upper 60's) and the car smoked constantly after start up for about 7 minutes. Also smoking whenever the engine is revved. Exhaust is sounding very different. Lots of pops, backfires, and just sounds more uneven than usual. Dealership said NOTHING was wrong lat week. I am having some trouble believing that. The engine is also starting to sound like it has a hell of a valve tick.
Can anybody give me some simple things to check so I can go in there and give them specifics?
#40
Man i have the same problem and the dealership said there was nothing wrong with it...i talked to a buddy of mine that has an 05 his oil smells like gas just like mine does...he said dont worry about anything because u will get a check engine light if its really an issue...
#41
#42
yeah thats what he said last night when we met up though...his is an 05 an mines an 06 same thing that his does mine does...hes done a complete rebuild with diamond piston and everything on his car so i think he knows enough to make me not worry plus were under warranty so if it happens take it on in for free...... i mean my exhaust pops and crackles i dont think you have anything to worry about personally
#43
Another update...
Trying to figure out what's wrong. If I pop off the oil cap when the car is running there is lots of air being pushed out. Enough to make the oil cap dance if you just leave it sitting in there unscrewed.
#44
...you have ring issues for sure man
#45
I love my dealer. They gave me the car back on Friday and they are telling me there is nothing wrong with it.
#46
#49
#50
