Is this ok??
Is this ok??
I just recently had the 2.8 pulley with 60lbs injectors installed on my 2.0 and now it louks (spelling) like a v8 or something. The RPM's dont move but my boost gauge moves just a hair up n down. Is this normal? Also just a note I am runnin a tad Rich.
2FST you need to tune it after those parts are installed.... I just got my 60's in Sunday and it needs tuning before you run it.... also take some carb or brake cleaner and spray it around the injector holes and listen for leaks... you will hear it suck the fluid inside.......
Call WickedSS and get it tuned ASAP!
If you aren't tuned your car is still under the impression that you are running 42s.... get it tuned ASAP!
The reason I state check for the leaks, is when Area47 and I did mine on Sunday the #2 injector wasn't seated all the way in... causing it to jump around at idle and when we sprayed the carb cleaner you can hear it sluuurp the fluid in...
