only 10 psi boost with stage 2 gm???
ive heard of a mon that can fix this issue with low boost... my cats not plugged just low boost.... i feel i should be getting around 14 or so but i cant seem to get past 10 any suggestions would be great thanks!
oh im kinda outta the loop on tha kinda stuff.... maybe ill have to get it checked is there some kinda specs i can find to at least show them what i should be getting?
https://www.cobaltss.net/forums//showthread.php?t=31602
check this thread i made it
that might be your problem
Is the bypass mod just disabling the SC bypass valve and if so what does that do? My tuner hooked that valve back up on mine and said it gave the supercharger a chance to cool when off the throttle. IDK?
take the bottom hose off ur bypass actuator..fold it over and put a zip tie around it..
that will check the boost solenoid.
If you get full boost then your boost solenoid is not completely closing..
