Opinions on LSJ build...?
Old 09-19-2014, 12:00 PM
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by MonsterDude72
I went home and tried to find that sheet of paper that said the size and all that with no luck. If i do have #42 injectors. will i be fine?
thanks for this! helps a lot. I just wish i would of saw this sooner!
If you do have 42's you will be fine with your pulley size and setup. GMPP 42's will support more than most think.
Old 09-19-2014, 01:58 PM
MonsterDude72's Avatar
Good to hear. Thanks!
Old 09-19-2014, 02:17 PM
blueLNFftw's Avatar
Shall I post my HPT logs of my car doing 127% duty cycle on the OEM 42's and OEM 3.06" stage 2 pulley? And the ones of it doing 143% on the 2.9" pulley?
Saying they will be fine is kind of a blanket statement because of other factors.
Old 09-19-2014, 02:22 PM
Administrator
Administrator
Staged07SS's Avatar
For his setup he will be fine.
My car has been running them for 7 years without one issue, and has been through many different setups and pulley sizes. I know what they can and can not handle.
I've been around for many years. I do not need to see your logs. I've seen many logs and many different setups. Again, he will be fine.
Old 09-19-2014, 03:49 PM
mrbelvedere's Avatar
I ran 3.0 on 42s no problem if your idc is that high you have something in the tune off
Old 09-19-2014, 08:14 PM
blueLNFftw's Avatar
It was the GM tune.
I had a whole thread about it month back, you even posted in it.
Two other tuners looked at the file as well.
Nothing was wrong with the injectors either, in fact, another member here has them now and they are fine.
Old 09-22-2014, 07:09 AM
Administrator
Administrator
Staged07SS's Avatar
I had no problem with my 42's on the dyno over the weekend.
Old 09-22-2014, 08:44 AM
blueLNFftw's Avatar
What was the duty cycle on them?
Old 09-27-2014, 06:40 PM
Ok so i need help with a concern. I have everything together but its making a strange whining. And no its not the supercharger. It almost sounds like its coming from the motor mount. Any ideas?
Old 09-27-2014, 09:25 PM
Blowncavy's Avatar
Belt? Tensioner?
Old 09-28-2014, 09:57 PM
  #36
Originally Posted by Blowncavy
Belt? Tensioner?
I guess its the water pump. Not the thing i wanted to hear when i just replaced all the timing.
Old 09-28-2014, 10:01 PM
  #37
enjoy changing it in the car its a pain in the ass and get the lyle water pump tool if you don't pull cover
Old 09-28-2014, 10:11 PM
  #38
So it is possible to do it without pulling the front cover off?
Supercharged06SS
12-11-2022 04:47 PM
06MetallicBalt
08-17-2021 03:40 PM
Tupp
09-30-2015 08:18 PM
importkiller
09-30-2015 07:18 PM
09-28-2015 12:51 PM
Quick Reply: Opinions on LSJ build...?
