Option B air bleed restrictor
Hey guys, just installed my dual pass and option b but i am having problems with the air bleed line from the heat exchanger to the reservoir. I know that the kit call for a .040" fitting but all that i could find around here was .070" and the air bleed line is shooting coolant like a squirt gun into the reservoir. I have the .070" restrictor pressed in the hose immediately after the fitting on the heat exchanger but not pressed into the fitting.
So my question is will the .030" difference of the .040 stop the coolant from shooting out or do i have the fitting in the line incorrectly?
I was wondering the same thing.. I didnt know where/how to put in that little black reducer. I got the zzp stage 3 one. Not sure what one you have.
In for answers tho
Dont really know how to bleed the H/E besides what I read on other threads. just let it do its thing.
In for answers tho
alright so i drill a piece of aluminum to .040 put it the line directly after the brass fitting on the heat exchanger and im still getting a slow but steady stream of coolant to the reservoir. I'm at a loss any other ideas anyone?
OrangeCoba
09-25-2015 06:06 PM
