Option B Kit
#77
ok real quick
i guarentee you mine is better than option B alone. i guarentee you that option B with the endplate would own my system. option B is for coolant expansion and nothing else. mine allows you to actually introduce DOUBLE the amount of fluid actually running through the system. i woudl bet my tank with a dual pass would exceed the performance of the option b with endplate.
i like the fact you guys are saying "well its hotter here so its not the same." dumbest argument ever.
READ-
both kits are designed to REDUCE HEAT SOAK. that is the case if its 30* outside or 500* heat soak is heat soak, and the goal is to make it take longer for it to set in. by mine having more fluid and it actually flowing through the system it will take LONGER to heat soak. do you freaking get it now?
READ-
lawls hahaha
Last edited by 04redline0124; 08-27-2008 at 08:53 PM. Reason: Automerged Doublepost
#78
ok real quick
READ-
READ-
End your arguement there, Thats what ive been saying since page 1. Your mod is for people dont dont have the money to do dual pass +opt b ANd im trying to do dual pass + option b im not trying to save money. SO can you guys take this stupid argument to your mod thread . GHEEZ
#80
http://files.filefront.com/sprint+ho.../fileinfo.html
130 degree IAT1s
I didnt see that mid-july in florida during vacation.
btw thats an OLD OLD tune and i dont even know where it came from.
130 degree IAT1s
#81
I was still going to retrofit my option b tank with hatrick's but wanted to find a better mount point so i could use the Option B mount point for my methanol instead of a trunk mount.
#83
Ill do you one better sell me your option b and get his mod and be done with it.
#84
#87
you have some serious issues. im not telling you you are a moron or anything, hell i already said i have no problem with it. im simply telling you what the better thing is. if you choose to go with a more well known product im perfectly fine with it. i dont need "my boys" to stick up for me. chill out
#94
#96
dude, get on my ass about it not him. The option B reservoir is a 2 quart container? I think hatrick's is 4? do the math guy. Its going to cool alot better because alot LESS HOT WATER is introduced in to the system. jeez. He didnt chime in until i went home for work.
