option b without dual pass??
I finally got my option b brackets and i am ready to do this already but i have a few questions...
1.I have a ZZP Heat exchanger and i wanna know how to run the option b kit without using a dual pass...
2. Can someone make me a diagram
3. Should i remove the filler neck?
1.I have a ZZP Heat exchanger and i wanna know how to run the option b kit without using a dual pass... (The dual pass is Option B!!)
If you are talking about moving the neck to a bigger reservoir just simply unhook mount reservoir & run lines to where the neck was, make sure to watch the fluid flow & keep it the same when hooking up to the new reservoir!
another words you need a 3/4 inch T, 2 hose clamps & 3 too 4 foot of 3/4 inch hose!
