OTTP Return style fuel system Worth it?
#53
Customer's original statement (lie)
Matt then refutes the lie here:
OTT then debates Matt and reiterates customers lie by using a thread where ZZP says Methanol can create more power (just as Matt stated) but OTT lies about what the statements from me say here:
My statement from that thread "they not only don't add HP, they take it away (when using anything but nearly pure alcohol)"
They did pull a thread, they did cite a post but they lied about what it implied as did the OP. I have repeatedly stated the EXACT same thing. My position has not changed, nor have the facts. The only thing that has changed is that there is now more evidence on the board backing up my statements. Water will make the car lose HP, alcohol will make the car gain HP and a combo of the 2 will have a mid point with zero gains depending on mixture. In the thread cited by OTT I said 'nearly pure alcohol', we are now talking about 90% methanol 10% water, exactly as I stated.
The $1000 challenge still remains, the facts still remain. Nothing ZZP has been posting has been changing or proven wrong.
Now there are plenty of people lying about what we said. Changing words such as the lie above by short stack but the position hasn't change. This is called a straw man arguement and it runs rampant here. When you cannot prove your opponent wrong, you just change what he said and prove your new changed statement and declare victory.
In the above short stack is lying. He's quoting me, saying that I claimed something about meth injection. I did not. Ever. The above is not my quote and my saying it is, shorstack is lying. The statement I made about meth was that it makes 5% more power than gasoline and people here often confuse it with water. And I'm sure that quote will be taken out of context, edited, changed, misconstrude and used to bash me again once people start making up more lies...
Seeing as how our first build with a twin charged schooled every doubter and smashed the forums HP record, I'll take that as a victory (again)
You just said the $1000 dollar challenge... so then enlighten me as to what it is?
And.. actually.. that was not a direct quote.. Did i say you said that? Did i imply that you said that? No...
In fact, i said that it was the "thread" i was referring to, the quotations being the general overlook of the thread itself...
Show me where it says "zooomer said..."
#55
Heres a good one....
You just admitted to having a $1000 challenge.
So, you said i was lying about something.. but at first admitted that it was there? weird.
How is this in ANY way "quoting" something you said?
#56
somehow he will turn these statements so hes right and everyone is wrong. we all know that ZZP is run by the king of all Bullshitters, now we just have to spread the word. word of mouth travels pretty damn far.
#58
You quoted Zoom in an attempt to make it appear that he said METH does not work. Please try to comprehend what he is actually saying. Meth works great. The more water you add to it, the worse it works. As you add wore water to the meth/water mix, at some point, your potential for HP will decrease. Washer fluid is far below the level of meth required for HP gains.
#59
That's another blatant lie. They blamed the boost regulators and bought new ones which did not cure his problem. The real issue is that the car left our shop and was promptly modified by another shop with poor results. We clearly stated before the build that the open wastegate dump would be loud. When the customer picked up the car, boost control was flawless. He decided that he wanted the car quieter and went to a different shop for turbo kit modifications. After the wastegate system was altered by that shop and random people started altering the tune, the boost control never worked correctly again. Now, a few months later, I'm here reading that there was some sort of admittance of mechanical failure. It's ridiculous, to say the least.
#60
#61
I have to admit, I'm not a fan of ZZP's products or Zooomer's personality but the amount of misinformation and blatant slandering in this thread is ******* ridiculous.
#62
