ottp stage 1 questions
I'm going to order the ottp satge 1 kit but I need some opinions on these 2 options, whats the best rev limiter rpm and what is stock set at? and torque managment was is it and should I remove it?
Rev Limiter RPM: 7000 7200 7400
Remove Torque Management: Yes No
UPDATED
ok order it yesterday along with the h/e and the puller and installer tool to any advice for installing?
UPDATED
and i got my rorque management turned off. up to you tho. i would do it
torque management pulls timing in the begining of each gear when you are "banging gears" this is done so less stress is applied through the transmission while you are doing this.
I will be honest I drive my car hard I think I will go with a 7000 rev limiter because I'm always hitting it when racing, I think I need a shift light I like to keep my eyes on the road and not on the cluster....and from your guys advice turn torque management off then
Anyone know how to turn torque management off in hptuners? I maxed out my MAF vs. Boost table (can't remember what its called right now), but how do I get it to not pull timing at the beginning of each gear? Or do I just go into main spark advance and do it there?
find somebody with hptuner local so u can get crank position relearn from them your car doesn't have to be unlocked cuz it just uses the scanner part of it....and when u the relearn on hp tuner press the brake pedal down an than rev it up
