P0301 intermittent misfire HELP!!
Old 05-28-2012 | 06:57 PM
mrbelvedere's Avatar
you have 3 grounds 1st is in the trunk from the battery 2nd is on the valve cover to head and 3rd is right behind the drivers side headlight to block you also have some sensor grounds that are under the oil cooler also
seafoam isent needed you just had the head off
Old 05-29-2012 | 06:06 PM
B_RADSS's Avatar
Update so last night as I was pulling in my driveway it started running like crap so I popped the hood as it was idling...removed connection to coil pack cylinder no. 1 idle speed did not change...so to be sure It was a coil pack problem I switched 1 and 2 started it up it ran fine and unplugged coil pack connection to cyl no. 1 and it ran like it does when misfire occurs...soo I switched them back to be sure and started it up again and it ran fine with the original coil pack in cyl no. 1??
Old 05-29-2012 | 06:12 PM
B_RADSS's Avatar
They are brand new spark plugs and not the janky cheap ones no way they are fouled yet not even 2000 miles on them...I cleaned all the plugs and put them back in and now it runs fine the code I'm throwing now is p0420 which is cat efficiency below threshold bank 1 keep in mind I have a zzp catless dp and did the non fouler trick already...it just doesn't make sense that it would throw just p0301 then just p0420
Old 05-30-2012 | 01:36 AM
insylem's Avatar
It does look like it spins up backwards, but in all fairness its a video. WHen things rotate on video the frame rate of the video and speed of the rotation can create the optical illusion of spinning backwards. Example: Old western wagons wheels spinning backwards in movies.
Old 05-30-2012 | 10:48 AM
replace the engine harness
Old 05-30-2012 | 07:29 PM
B_RADSS's Avatar
I am considering it just need to find one
Old 05-30-2012 | 07:41 PM
Edubs's Avatar
Danny Cin is selling a harness I believe. Look in the classifieds...
Old 06-01-2012 | 04:32 PM
B_RADSS's Avatar
Your not gonna believe what fixed it.... 2 vacuum lines were switched and 1 injector wasn't seated properly took me a while but I'm glad It was this simple and in the process I found my tranny mount completely cracked and off my tranny would explain some of the hard shifts lol
Thanks for the help everybody!!
Sean Cummings
03-09-2018 01:26 AM
Dustin24
47
02-12-2016 05:10 PM
satisfied
10-19-2015 01:35 AM
717ssbalt
10-02-2015 05:01 PM
allpro666
09-23-2015 08:47 PM
