P1133 Code
I'm too JDM for you
an engine is tuned to switch between rich and lean during cruise. ~14.7AFR is stoich. the higher the number the leaner, the lower the number the richer. they are designed to go rich to lean many times per second(its an emissions thing). if it does not switch enough you throw the insufficient switching code
OrangeCoba
09-25-2015 06:06 PM
