pacesetter headers
cmon guys dont be such a dick! he just asking
as far as i have read, people say that it is great as far as you cut the bolt joint.
in my personal opinion for the price i cant be that bad either. i dont know anyone here (PR) that have it but a lot of people in this forum have it.
Nah u don't cut the ball joint to fit you cut the ball joint cuz it has like a 2 or 2.5 in opening but its a 3in collector. So basically u cut the joint off to make it a 3in out header. I have mine attached to a catless dp if u want it
Send me a pm if you are intrested in the header/dp
X2, check out www.TurboTechRacing.com for the OP if you are interested in one. We should be the lowest out there, and have them in stock. PM us if you would happen to find it lower, we should be able to price match.
You will get that from ANY header, due to the wall on a header is tubing/thinner than the stock thick cast manifold. Nothing to do with pacesetter. It is the sound transfer properties of the less dense material/thickness.
You most likely know this, just wanted to make sure everyone knew it was not brand specific.
