Pics of my CTI Header and DP! (56k Beware)
Old 09-21-2006, 08:53 PM
Bad06SS's Avatar
Hey guys! I just got my CTI Race Header and 3" catless downpipe! I must say, I'm extremely impressed! The build quality is amazing, and gaskets are included! There's a copper manifold gasket, and even a donut gasket for the collector and downpipe. CTI did a great job on this header, and they were even nice enough to make the way I requested. Also, thanks to Mike at New Era Performance for the great customer service, and sweet price on this! Here's the pics, there's definetely a big difference between the CTI and the stock manifold!
Old 09-21-2006, 08:55 PM
ocp04's Avatar
what does this combo go for and where can it be purchased?
Old 09-21-2006, 08:57 PM
Bad06SS's Avatar
I purchased mine from Mike at New Era Performance.
www.neweraperformanceparts.com
I'll PM you with the price.
CTCOBALTSSS's Avatar
Looks good Bad06! Well what do you know, there is the manifold.
Your set up looks kick ass. Keep up the good work.
Old 09-21-2006, 09:00 PM
Bad06SS's Avatar
Thanks! Just so you know, that's the stock manifold in the picture, NOT the GMPP manifold. I'm hoping to start on the install tomorrow night, and I'll take some pictures of the GMPP manifold then. Thanks again, I must admit, I'm more pleased than I thought I'd be! I can tell you after seeing this in person, for people wanting a "long tube", this is the way to go!
Old 09-21-2006, 09:08 PM
Bad06SS's Avatar
Oops, just realized I should've put this in the Pics/Video's section. Sorry mods, feel free to move it.
Old 09-21-2006, 09:14 PM
hatrickstu's Avatar
dude please dyno before you put it on, install and dyno agian!!!
Old 09-21-2006, 09:19 PM
Bad06SS's Avatar
Trying to find a dyno shop that's available when I am is like pulling teeth. I'm extremely busy, and only available during non-business hours. I can tell after seeing it in person that it should be worth some serious gains! I'll probably lose 2+lbs of boost! I'm putting this and a 2cnd heat exchanger on along with tranny mounts, then a ported blower, bigger throttle body, dual pass intake plate, and a ton a tuning. Once this setup gets dialed in, I think I'm finally done with modding the car.
Old 09-21-2006, 09:23 PM
SSinPhilly's Avatar
gl man!
Old 09-21-2006, 09:30 PM
Matty's Avatar
Looks nice.
FYI, I did lose 2 PSI when I swapped my cat out.
Old 09-21-2006, 09:34 PM
hatrickstu's Avatar
Originally Posted by Matty
Looks nice.
but i bet you are making more effecient boost
Old 09-21-2006, 09:37 PM
Matty's Avatar
For sure. Can feel a little nudge in the ass'o meter.
CobaltSS422's Avatar
right.. car isn't working as hard but making more power with less resistance
Old 09-21-2006, 09:39 PM
Shortbus's Avatar
Very nice.
Old 09-21-2006, 09:44 PM
DanJHartman's Avatar
i thought that it was bolted together in the pic, wondering why the angle on the DP didnt match up with the header
its different, i see the braided section is attached to the header instead of the DP, and no CAT?
regardless it looks clean and sturdy,
NOW
Sound clips and performance gains reports
good luck with it man
SpecialK's Avatar
Looks nice.
Make it sound like that's a bad thing.
Old 09-21-2006, 09:45 PM
glockglade's Avatar
can i get a good price on this without a cat?
Old 09-21-2006, 09:47 PM
SS_SC_Cobalt's Avatar
Good luck, almost will have what my setup is minus the Direct port nos, whoops did I say that out loud?
Old 09-21-2006, 09:49 PM
Matty's Avatar
Not at all. It's all about flow. High PSI doesn't necessarily mean more power. A high flowing engine making 13 PSI will make more than a resricted engine pushing 15.
Old 09-21-2006, 10:02 PM
Bad06SS's Avatar
Thanks for the response's guys! Fow what it's worth, I don't have a cat now anyway. On the stock downpipe, I had the cat cut off, and had a 2.5" straight pipe welded on. The difference now is the header, a 3" collector, and the 3" downpipe. I see 19.5-20lb of boost right now, I'm thinking I'll be at around ~18lbs after this, and keep in mind, that's with a 2.5" pulley! Most people see ~21lbs of boost with this size pulley. It'll be more efficient boost as mentioned, and it'll be cooler boost with the addition of the custom 2cnd heat exchanger. I will update results as soon as I can. I can tell scan log results, and 1/4 mile results.
Old 09-21-2006, 10:03 PM
Bad06SS's Avatar
Yes, I'll pm you.
Old 09-21-2006, 10:19 PM
cvenom2122's Avatar
pm me with a price too!
Old 09-21-2006, 10:29 PM
On a relatively stock car....
Old 09-21-2006, 10:49 PM
tityrous's Avatar
are those hoosier for ur cobalt... if so i look up to i need a set of slicks lol
Old 09-21-2006, 10:50 PM
Bad06SS's Avatar
It's worth quite a bit of power on a stock car, I bet my gains will be nice! Here is my mod list after Tuesday:
Custom Tuning
Snow Performance Water/Meth Injection Kit
Custom 3.5" CAI w/LT1 MAFF
2.5" Pulley w/Oversized Tensioner & GM Stage 2 Kit Belt
CTI Race Header w/ 3" Catless Downpipe
Corsa Touring Cat-back
Custom 2cnd Heat Exchanger
Spec 3+ w/Fidenza Flywheel
60lb Injectors w/Wiring Harness
ZEX plugs
JBP CAB's
INTENSE Poly Transmission Mounts
Drag bags
Aeroforce
Custom Fan and Intercooler Pump Switches
I would imagine on a 2.5" pullied car + bolt-ons that power gains will be very noticeable!
Quick Reply: Pics of my CTI Header and DP! (56k Beware)
