Pics of my CTI Header and DP! (56k Beware)
Old 09-21-2006, 10:51 PM
Bad06SS's Avatar
Originally Posted by tityrous
are those hoosier for ur cobalt... if so i look up to i need a set of slicks lol
Yes, those are my Hoosier Quick Time Pro's. Best 60' on those was a 1.95.
Old 09-21-2006, 10:56 PM
mken's Avatar
Originally Posted by Bad06SS
Once this setup gets dialed in, I think I'm finally done with modding the car.
That's what we all say, but has anyone ever successfully quit cold turkey? It'll at least take a 12 step program to end the modding cycle...
BTW, did you get replacement bolts/studs for where the manifold bolts to the dp with your header? My manifold used studs on it there, no bolts found in the shipping box, and there wasn't any studs on the new header, otherwise everything else was included.
Old 09-21-2006, 11:01 PM
Blown 4-banger's Avatar
Hey was your stock exhaust manifold flange bolts (the three bolts that connect the exhaust) a bitch to get off? It took me 3 DAYS to get them off!!!
Old 09-21-2006, 11:18 PM
Bad06SS's Avatar
Originally Posted by mken
That's what we all say, but has anyone ever successively quit cold turkey? It'll at least take a 12 step program to end the modding cycle...
Thanks for the heads up. No there was no bolts in the box. What did you use?
Old 09-21-2006, 11:19 PM
Bad06SS's Avatar
Back when I had the GMPP installed, Rob was the one to take it off, so I'm not sure. Sorry buddy.
Old 09-21-2006, 11:21 PM
Oh, just thought I'd ask. Just wanted to know if I was the only one who had stupidly tight bolts.
Old 09-21-2006, 11:22 PM
Bad06SS's Avatar
I would imagine that's normal.
Old 09-22-2006, 12:04 AM
2fastSS's Avatar
so will this header fit right onto the corsa exhaust??
Old 09-22-2006, 12:10 AM
Bad06SS's Avatar
As far as I know, yes. I'll let you know if I run into any problems.
Old 09-22-2006, 12:18 AM
2fastSS's Avatar
ok cuz if so im gonna buy it but with the high flow cat
Old 09-22-2006, 07:02 AM
  #36
DWK5150's Avatar
Question. That piece of flex pipe is that welded to the header? What happens if you get a leak in it can it be cut off to be replaced??? Just a concern I would have.
Old 09-22-2006, 08:19 AM
  #37
SS_SC_Cobalt's Avatar
just tell ***** that you want the 2.5" neckdown
Old 09-22-2006, 08:23 AM
  #38
It's worth quite a bit of power on a stock car, I bet my gains will be nice! Here is my mod list after Tuesday:
Custom Tuning
Snow Performance Water/Meth Injection Kit
Custom 3.5" CAI w/LT1 MAFF
2.5" Pulley w/Oversized Tensioner & GM Stage 2 Kit Belt
CTI Race Header w/ 3" Catless Downpipe
Corsa Touring Cat-back
Custom 2cnd Heat Exchanger
Spec 3+ w/Fidenza Flywheel
60lb Injectors w/Wiring Harness
ZEX plugs
JBP CAB's
INTENSE Poly Transmission Mounts
Drag bags
Aeroforce
Custom Fan and Intercooler Pump Switches
I would imagine on a 2.5" pullied car + bolt-ons that power gains will be very noticeable!
Nice mine is almost the same....
dont have the CAI and maf custom, but I have a 3" cat back to the 3" header
have a bolt in 3" catless pipe for off road Catted pipe for on road
NGK copper plugs
no drag bags
no custom fan and pump switches....
NX Nozzle kit w/75 hp jets right now
2.5" pulley for the track, 2.6 street
Old 09-22-2006, 08:24 AM
  #39
it is unlikely, inside that is a ribbed flex pipe, the mesh is for reinforcement!
Old 09-22-2006, 08:51 AM
  #40
CTCOBALTSSS's Avatar
Custom Tuning
ZEX plugs
JBP CAB's
Drag bags
Aeroforce
That is a kick ass list! WOT!!
Old 09-22-2006, 09:54 AM
  #41
Bad06SS's Avatar
NGK copper plugs
no drag bags
Wow, a 75 shot on a 2.5" pullied car! I think I'd be a little too scared to do that. How's it working for you?
Old 09-22-2006, 09:56 AM
  #42
well so far at a couple of close friends recommendations and my own math, I have only shot on a 2.8
the 2.6 is the next try
  #43
Bad06SS's Avatar
Thanks! I'm hoping with that list, a ported blower, SMS Throttle body, and a ton of tuning, that this car is capable of running 12.5s'-12.7's@110-112mph. Traction pending of course. I would also like to see how close to 300whp I am after as well.
Old 09-22-2006, 09:58 AM
  #44
Yeah SS SC you are a crazy son of a bitch.
Lets see here.....
2.5" pulley
75 shot of nitrous
3" everything
Crazy SS SC
Old 09-22-2006, 09:59 AM
  #45
the SMS makes a big difference when you have the ported S/C
Old 09-22-2006, 10:14 AM
  #46
DWK5150's Avatar
You have the SMS on your car?
Old 09-22-2006, 11:19 AM
  #47
Bad06SS's Avatar
Well, if you keep the AFR safe, retard some timing, and aren't getting any KR, I would THINK you'd be ok. You definetely need to get some track times spraying with a 2.6" pulley!
Old 09-22-2006, 11:22 AM
  #48
DWK5150's Avatar
I gotts say I have spray now but I am affraid to try it with the 2.5. I tihnk Ill step down to a 3" to try it out for the first time.
Old 09-22-2006, 11:23 AM
  #49
plyboy-illest's Avatar
looks good man
Old 09-22-2006, 11:53 AM
  #50
yep!
CT you are one funny ass dood!
Remember when you have a 400+hp SRT
2XX anything HP is just too damn slow!
Quick Reply: Pics of my CTI Header and DP! (56k Beware)
