Please take time and read..
So I really dont know what else to get other than brakes...any suggestions?
this is the build my car is currently under going..
The short block is an AAS stage 1:
Decking, honing and balancing
AAS custom ground balance shafts
polished con rods
Wisco forged aluminum pistons (10.1:1)
Rings
complete longblock built to AAS specs.
Head is going to be a AAS stage 2:
Flow Bench miled and ported head
GM valve seals
Ferrea +1mm valves
ferrea valve springs
ferrea spring locators
ferrea Titainium retainers
272 grind cams
5 angle valve job
complete assy by AAS tuning onto stage 1 block. With ARP head studs.
Complete installation of engine including excedy stage 3 clutch, qualfie lsd and dual pass end plate. And complete tuning for 8000rpm with water/meth injection from AIS with pump gas. Just about 370-400WHP
supercharger ported and polished repacked bearings and new oil
all of this will be in addition to the mods I already have:
K and N cold air intake, 2.7 pulley, 60lbs injectors, cobra heat exchanger, gm stage 2 belt, zzp header, 3inch zzp downpipe, magnaflow highflow cat, magnaflow cat back exhaust, Custom air bag suspension from Kreative Kustomz, Turbo Tech Passenger side engine mount, Turbo Tech Tranny prothanes, hurst short shifter
already have the show side of the house covered too so no need for recommendations on that just looking for preformance for now
polished con rods
Rings
GM valve seals
Ferrea +1mm valves
272 grind cams
5 angle valve job
50? with a good build you should have no problems continuosly running at LEAST a 75 shot. Hell, id do 100. If you have money to throw around, why not do coilovers or that new airbag system??
air bag suspension (already have)
rksport 3 peice wing(have)
custom lip kit(have)
shave antenna and trunk key
custom paint (not saying until its done)
i have 20s already..also i have the twin sub frame bar on order waiting for number 10..
and my complete system...2 jl audio w6s with a 1000/1 jl amp, jl 300/4 for my highs..clarion double din with custom dock for my iphone, a few tvs..i have a cf hood for daily driving but a split stock hood motorized for shows..i mean can i really be this close to being DONE...oh and im looking for a sedans rear door handles that dont have locks because i dont want to shave my doors but dont want the ones we have on our coupes
lol cars are my thing..i dont know much about cameras..i got a good one when i was stationed in japan but its not like one of the ones some of u have its more of a good 10 mega pixel quick pic camera
yeah i donno much about camera's myself..all i know is these new dslr camera's people are getting are making everyone look like pro photographers
a nice hid retrofit would be cool..and i know somone makes an aftermarket hud unit ( heads up display, deplays like your speed and rpm's and projects it onto your windsheild somehow
and a nice alarm is a must for your car
yea i wanna get the stg 5 axles and some falken 542s for daily driving and going to the track..i wanna get the baer big brake kit so there goes 16's and drag slicks
