Pop goes the weasel ;(
Old 11-30-2012, 09:21 PM
TStone's Avatar
yeah the bearing would be fairly easy to replace.. but would require pulling the rods
Hopefully everything else is still in tact down there
Old 11-30-2012, 09:40 PM
mrbelvedere's Avatar
if you spun a rod bearing the crank is done
Old 11-30-2012, 10:34 PM
MrSlickSter06SS's Avatar
YEah lol I just thought of that but I highly doubt I spun a baring im thinkin piston or piston ring like tstone.
Old 11-30-2012, 10:44 PM
Tjolley's Avatar
well if its knocking the only thing i would think it is a rod bearing
Old 11-30-2012, 10:49 PM
yeh but even when a piston ring goes it makes a knocking sound I heard other peoples cars to in the past who lost a ring, and the sound is pretty comparable.. I am just gonna have to get down and dirty to know for sure..
Old 11-30-2012, 10:54 PM
Tjolley's Avatar
ive blown 2 engines a stock one and a built one..
wen i cracked both stock pistons me engine seemed to run fine eexcept wen i got on it. it would blow th dip stick out cuz all the blow buy
Old 11-30-2012, 11:33 PM
Lol wow yeah the dip stick is not blowing out haha..
Old 11-30-2012, 11:43 PM
South Central *********
JapEatr's Avatar
Timing chain tensioner fall apart and end up in oil pan?
Pull valve cover and oil pan and inspect
Old 11-30-2012, 11:45 PM
chris88z24's Avatar
Cold weather + 2.8" on 42's? Not surprised.
Old 11-30-2012, 11:49 PM
JapEatr's Avatar
I ran the snot out of 2.8 on stage 2 tun from gm for years. Something failed
Either roller rocker, tensioner or ring land
Old 12-01-2012, 12:44 AM
  #36
HUm is that common? I've never seen anyone run into that issue before? and I'll do that for sure. Thanks!
007Buff
06-11-2017 03:04 PM
10-21-2015 11:57 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: Pop goes the weasel ;(
